titans project skip build - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > titans project skip build
Old Streetfighter Motorcycle Forum Post 11-01-2019, 07:45 AM   #1
titan
hooligan quads
titan's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 03:27 PM
Flip Offs: 3
Flipped Off 14 Times in 2 Posts
titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!
Default titans project skip build
┼plan is to get this one as a runner, by the closing date as cheaply as possible. the build if you havnt been following is a bandit 600 frame, GSXR1100 engine, SRAD 750 front end.
to do!!
subframe
engine rebuild
wiring
pretty much every thing and still missing key components.
currently in this bike for ú193
see how we get on
ride it like you stole it
Customization not Restoration
Originally Posted by Albert Einstein
I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.
H Designs
2020 build off - build - chat
titan is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived titan!
Old Streetfighter Motorcycle Forum Post 11-01-2019, 03:53 PM   #2
titan
hooligan quads
Flip Offs: 3
Default Re: titans project skip build
Well no time to seat around, new job Monday means less time on the bikes.
First job sub frame, so made a start on that. Made the bracket it's need to weld it up just tacked in place for now. that will get welded to the frame top rear shock mount. Made the back bone of the subframe, this is the two bend tubes I had that are now bridged together. this now needs gussets to strengthen it up and the frame supports making. Then I need to remove the old remainents of the original subframe.
Also got a package with my bottom yoke in.
Sent from my SM-G973F using Tapatalk
H Designs
Old Streetfighter Motorcycle Forum Post 11-02-2019, 03:09 PM   #3
titan
hooligan quads
Flip Offs: 3
Got the bracket for the subframe welded from the underside, still play the game of luck when it come to Tig, still lots of room for improvement but happy with how that welded up. Top will all be welded up together once finished.
Cleaned up the rear of the frame and happy with the lines. Now to make this all a bit stronger. Plan is to have two supports made out of 12mm solid bar, I'll gusset the back bone up on the bend and on the rear side (front side of the bike). At some point there will be a platform added that will sit under the frame for the battery and electrical crap. This should add the final bits of support if needed. Oh and the back bone will be cut down by about 9", as I don't need it out that far.
Does anyone see anything I have missed with this design in terms of structural integrity??
H Designs
Old Streetfighter Motorcycle Forum Post 11-02-2019, 03:13 PM   #4
titan
hooligan quads
Flip Offs: 3
Oh and rough design
H Designs
Old Streetfighter Motorcycle Forum Post 11-03-2019, 01:32 PM   #5
titan
hooligan quads
Flip Offs: 3
Last bit before work this week. Got the Gussets done on the under side. Need to order my seat now so I can get it measured up and trim off the fat.
Just waiting new engine cases so I can get the engine done and use the old one for a mock up
H Designs
Old Streetfighter Motorcycle Forum Post 11-08-2019, 06:18 PM   #6
titan
hooligan quads
Flip Offs: 3
Engine cases turned up. stripped out some of the old parts left in it, and gave them a clean at 65'c ( don't tell the wife!!)
The new cases are from a k series, I'm starting to think the engine I have is not a k series but another 1100/1200 engine, pistons are 78mm. They looks the same ( a few differences) but the numbers are all different... See how that goes.
Also removed the subframe bracket as I notice it was off by about 5mm to one side. Just needs a slight trim and re tacking on
Re set up my Tig to try something new
H Designs
Old Streetfighter Motorcycle Forum Post 11-09-2019, 10:41 AM   #7
titan
hooligan quads
Flip Offs: 3
Not much done been super busy but did get the bracket tacked back in place. Also picked up some parts price to be negotiated later
H Designs
Old Streetfighter Motorcycle Forum Post 11-10-2019, 01:05 PM   #8
titan
hooligan quads
Flip Offs: 3
Not much done this weekend. I did get a few brackets drawn out ready to cut next week. Engine case cleaning this week ready to paint next week hopefully. Nothing worth pictures sorry.
Oh seat ordered
H Designs
This user High Fived titan!
Old Streetfighter Motorcycle Forum Post 11-11-2019, 03:23 PM   #9
titan
hooligan quads
Flip Offs: 3
budget now at ú203 spent total
H Designs
Old Streetfighter Motorcycle Forum Post 11-14-2019, 04:08 PM   #10
titan
hooligan quads
Flip Offs: 3
We have a seat
H Designs
Thank you for viewing titans project skip build in the 2020 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2020 Winter Build-off Build Threads - titans project skip build on Custom Fighters Streetfighter Motorcycle Forum
