Honda Hornet 599 Retro-Fighter - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Honda Hornet 599 Retro-Fighter
Old Streetfighter Motorcycle Forum Post 12-21-2019, 01:18 AM   #1
JAGspeed
Active Member
Fighter
JAGspeed's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 11:17 AM
Flip Offs: 1
JAGspeed is a wicked helpful, well liked member!JAGspeed is a wicked helpful, well liked member!JAGspeed is a wicked helpful, well liked member!JAGspeed is a wicked helpful, well liked member!JAGspeed is a wicked helpful, well liked member!JAGspeed is a wicked helpful, well liked member!JAGspeed is a wicked helpful, well liked member!JAGspeed is a wicked helpful, well liked member!JAGspeed is a wicked helpful, well liked member!JAGspeed is a wicked helpful, well liked member!JAGspeed is a wicked helpful, well liked member!
Fighter of the Month Winter Buildoff Winner Fighter of the Month
Default Honda Hornet 599 Retro-Fighter
Picked up a running 06 Honda Hornet that someone had already started to cut up and turn into a café racer. Lucky for me his skills didn't match his ambition so he gave up on the project and I got a great deal. So I had an idea and some inspiration from an old Honda classic. The CB700SC Nighthawk. I figured I could combine the two and have a more modern bike with a classic look. Not going to crazy on this one only because I still need to finish other projects.
ID:	107014   Click image for larger version
JAGspeed is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived JAGspeed!
Old Streetfighter Motorcycle Forum Post 12-28-2019, 08:57 PM   #2
JAGspeed
Active Member
Fighter
Flip Offs: 1
Default Re: Honda Hornet 599 Retro-Fighter
Found a clean tank and tail section from a Nighthawk. Fitted the tank up and made the front mounts for it. I also trimmed the Hornet side panels a bit. I going to try and tie the side panels into the Nighthawk grab rail somehow. I will have make new mounts for the coils to fit under the new tank.
Name:	CB tank b.jpg
ID:	107022   Click image for larger version
Name:	CB tail a.jpg
ID:	107024   Click image for larger version
Name:	CB tail mnt.jpg
ID:	107026   Click image for larger version
Name:	CB  L side a.jpg
Old Streetfighter Motorcycle Forum Post 01-01-2020, 05:04 PM   #3
JAGspeed
Active Member
Fighter
Flip Offs: 1
Made more progress on the subframe to support the seat , tail section and side panels. I will also mount all my electronics to this.
Name:	CB sub frame a.jpg
ID:	107060   Click image for larger version
Name:	CB sub frame b.jpg
ID:	107062   Click image for larger version
Name:	CB sub frame c.jpg
Old Streetfighter Motorcycle Forum Post 01-02-2020, 11:20 PM   #4
JAGspeed
Active Member
Fighter
Flip Offs: 1
Originally Posted by yantosh View Post
should move this to the build off
Looking back I should have just started this in the build off thread. Not sure how to get it moved there now???
Old Streetfighter Motorcycle Forum Post 01-05-2020, 06:03 PM   #5
JAGspeed
Active Member
Fighter
Flip Offs: 1
Had the idea to mate the Hornet side panels to the Nighthawk grab rail. I was able to join them enough so when I make the seat it should look fairly seamless. Also welded up the mounts for the grab rail. Cut the tail section down and mocked it up. The grab rail is really just for more of an authentic look considering I have reduced the bike to a single seat.
Name:	CB sub frame d.jpg
ID:	107074   Click image for larger version
Name:	CB sub frame e.jpg
ID:	107076   Click image for larger version
Name:	CB sub frame f.jpg
ID:	107078   Click image for larger version
Name:	CB sub frame g.jpg
Old Streetfighter Motorcycle Forum Post 01-10-2020, 10:20 PM   #6
JAGspeed
Active Member
Fighter
Flip Offs: 1
I lowered the position of the grab rail to give it a sleeker look but in doing so I made it wider at the top because the side rails went up at an angle. I bought a 2nd center piece so I could lengthen it to fit. Cut both pieces and welded the 2 longer parts together. I cleaned up the welds and bolted it back together.
Name:	CB  grab rail a.jpg
ID:	107106   Click image for larger version
Name:	CB  grab rail b.jpg
ID:	107108   Click image for larger version
Name:	CB  grab rail c.jpg
Old Streetfighter Motorcycle Forum Post 01-15-2020, 07:36 PM   #7
JAGspeed
Active Member
Fighter
Flip Offs: 1
Made my mounts for the electronics kept everything fairly close to where it was originally mounted that way I don't have to cut up the wiring harness to much. I used a smaller brake reservoir for a better fit under the seat.
Name:	CB wiring a.jpg
ID:	107174   Click image for larger version
Name:	CB wiring b.jpg
ID:	107176   Click image for larger version
Name:	CB wiring c.jpg
Old Streetfighter Motorcycle Forum Post 01-24-2020, 10:39 PM   #8
JAGspeed
Active Member
Fighter
Flip Offs: 1
I wanted a small belly pan that fit the shape of the tank and tail. I had a lower fairing lying around off a Chinese pocket bike so I cut it down to fit and made a couple of brackets to hold it in place. Also used a rear hugger fender off the same bike added some support trimmed it to fit painted it black and mounted her up.
Name:	CB lowerl a.jpg
ID:	107382   Click image for larger version
Name:	CB lowerl b.jpg
ID:	107384   Click image for larger version
Name:	CB  hugger b.jpg
ID:	107386   Click image for larger version
Name:	CB  hugger a.jpg
Old Streetfighter Motorcycle Forum Post 01-25-2020, 08:41 PM   #9
JAGspeed
Active Member
Fighter
Flip Offs: 1
Cut off the passenger pegs. I left a little room on the backside of the right rear set to possibly use as an exhaust mounting point. Man these had some weight to them probably lost 4-5lbs.
Name:	CB  rear set a.jpg
ID:	107390   Click image for larger version
Name:	CB  rear set b.jpg
ID:	107392   Click image for larger version
Name:	CB  rear set c.jpg
ID:	107394   Click image for larger version
Name:	CB  rear set d.jpg
Old Streetfighter Motorcycle Forum Post 01-29-2020, 07:37 PM   #10
JAGspeed
Active Member
Fighter
Flip Offs: 1
Started on the seat. I taped off everything so I could make a fiberglass base for the seat. I used a release agent over the tape so it could be removed easily then I laid down the glass. After trimming it up set it back in place, fit like a glove. Just need to layer in some seat foam and shape it up.
Name:	CB seat a.jpg
ID:	107442   Click image for larger version
Name:	CB seat b.jpg
ID:	107444   Click image for larger version
Name:	CB seat d.jpg
Thank you for viewing Honda Hornet 599 Retro-Fighter in the 2020 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2020 Winter Build-off Build Threads - Honda Hornet 599 Retro-Fighter on Custom Fighters Streetfighter Motorcycle Forum
