Casper's 1994 Yamaha XJ600 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Casper's 1994 Yamaha XJ600
Old Streetfighter Motorcycle Forum Post 03-21-2010, 06:33 AM   #1
Casper
The friendly Ghost.
Local Time: 03:38 AM
Flip Offs: 190
Default Casper's 1994 Yamaha XJ600
So this is my little toy I got for my first bike. I got it to learn how to ride and so that I could work on it. I bought it instead of the more popular bikes because I did not want to get in the habit of buying bolt on parts and would rather learn how to fabricate my own. Enough chat, here is the pics you all love so much.
This is how I brought it home.
This happened a few days after I brought it home. Not all went back on.
Darn fuzzy pics.
These people High Fived Casper!
Old Streetfighter Motorcycle Forum Post 03-21-2010, 06:48 AM   #2
Casper
The friendly Ghost.
Flip Offs: 190
Default Re: Casper's 1994 Yamaha XJ600
So a little after I removed the plastics on the front and bought a Trail Tech Vapor gauge. I also got some Acerbis Cyclops headlights to stand in until I make my own set up. For some reason though, I keep burning out bulbs on the Cyclops. I need to figure out the wiring correctly. I also need to figure out how to use the stock tachometer sensor with the Trail Tech set up as the wire wrapped around the spark plug wire is just not accurate enough for me.
Here are more pretty pictures and a little teaser.
Can't leave them alone:2006 Suzuki SV650N, 1994 Yamaha XJ600S and 1979 Suzuki GS750LN
Time to find me a nice DRZ and VStrom...
This user High Fived Casper!
Old Streetfighter Motorcycle Forum Post 03-21-2010, 07:04 AM   #3
Casper
The friendly Ghost.
Flip Offs: 190
A few quick technical questions though.
The air box on my bike is not actually attached to the carbs. There are hose clamps there, but the inner diameter for the boots are smaller than the outer diameter of the carbs. Here is a picture of them sitting on top. When running it does not seem like a problem, but I would rather fix it before it becomes a problem. Also, how "clean" is clean enough, I prefer to not have to clean too often.
Another thing is that the crank case cover (number 3?) is in not too great of shape.
The front tire, although the arrow points the correct way, looks to me to be mounted b-ass-ackwards.
The treads can be seen really well here.
And the arrow and text here.
Old Streetfighter Motorcycle Forum Post 03-21-2010, 08:22 AM   #4
ROBBO
MAJOR FOOKIN' CATASTROPHY
Local Time: 06:38 AM
Flip Offs: 643
Good idea ta have tha air box on there correctly,tha outer cover should be replaced in casr bees make a nest in there and if tha rotation arrow is oriented rite then you are all set !.Clean bike is a absolute must mate ,you will spot any probs when cleanin and when its clean you are tha tits ontha road!Good luck ,I woodnt mind that fooker meself mate ..
PS tha seat? wots yer plans there bro.
PPS looks like ya gotta cylinder base gasket leak goin on there ..
ROBBO' 2009
These people High Fived ROBBO!
Old Streetfighter Motorcycle Forum Post 03-21-2010, 08:51 AM   #5
Casper
The friendly Ghost.
Flip Offs: 190
I was afraid you would say that, just so hard to want to clean it instead of wrench... Time to go do some cleaning.
I should have in not too long, an MSPaint or a Photoshop of what I want, but the tail will be made by hand (Time to try out some fiberglassing. ) and it will be level with tank like a modern sports bike. I will make a subframe (Time to try out some metal work?) that will raise it quite a bit, thinking of keeping the stock tank mount and just creating a triangle that connects at the rear of a solo seat two inches higher than the stock seat, leveling out the seat somehow and making something to cover the small triangle to match the tail and the tank together. I will try to make the tail look like either the R6s that will poke your eye out or a GSXR style tail, but keep the lines simple to follow the tank better. Later, I will try to make the exhausts into a single left exit very high mount exhaust or an under engine can with side outlet (After I replace the gasket and clean her up, otherwise that would be a disgusting can). I may have a picture of what inspired me somewhere. Talk about color scheme when daylight gets bright enough for pictures.
Here it is, cannot remember where I found it.
And the Exhaust similar to this.
Want to see another shitty pic of me needed to clean the engine and replace a few gaskets? Here it is...
Old Streetfighter Motorcycle Forum Post 03-21-2010, 02:46 PM   #6
Casper
The friendly Ghost.
Flip Offs: 190
Well, it's light out and I am awake, so I better follow through with the pictures of it updated.
Hours of sanding and figuring out how to use paint stripper, cleaning the tank of quite a bit, not all, but a lot and a lot of painting. There are at least seven layers of paint on each piece and 3 layers of clear coat all wet sanded until smooth. Took less than a week total and was a great project, I am happy with how it came out.
The yellow frame looks odd, I know. It is going to stay that way until I have the GS fully up and running and I decide to do the subframe for the XJ. The motor will be pained flat black as well as the headers and the frame will be either a bright red gloss, a blood red gloss, or a black gloss.
Old Streetfighter Motorcycle Forum Post 03-21-2010, 06:13 PM   #7
BMiller
That's Right!!!
Senior Fighterer
BMiller's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:38 AM
BMiller is making some friendsBMiller is making some friendsBMiller is making some friendsBMiller is making some friends
Off to a good start! BTW, that is my old '03 R6, I LOVED that Devil pipe
BMiller is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived BMiller!
Old Streetfighter Motorcycle Forum Post 03-21-2010, 07:45 PM   #8
Casper
The friendly Ghost.
Flip Offs: 190
Awesome.
Old Streetfighter Motorcycle Forum Post 03-24-2010, 01:09 AM   #9
Casper
The friendly Ghost.
Flip Offs: 190
I am currently bidding on a few sets of OEM HID projectors for cars and am looking at removing them from their housing and creating my own. Any quick hints?
P.S. I will edit post with a picture of what I want the headlight to look like in a little while.
Edit: This is what the concept light I was thinking of would look like.
All directions are from cockpit's POV.
Low beams are HID Projector in the left socket and Halo around the right socket.
High beam are the HID Projector in the right socket and the HID Projector in the left socket.
Left turn is the left eyebrow, this will either be a slightly curved halo or a curved line of LEDs.
Right turn is the right eyebrow, same as left turn.
The blue is the dashboard on the back of the assembly.
I already have the Vapor gauges installed, they will just screw into the housing.
The L and R will be yellow LEDs tied into their respective eyebrow.
The H is going to be a blue High Beam indicator light.
The N is the neutral indicator light, I currently do not have any indicators, just tach and speedo.
The OIL is going to be a red oil level warning light.
I am going to stick with either a skull, a ghastly face, or a face similar to the robots in I-Robot. I like their simple minimal yet aggressive design. The color will be the same matte white with matte clear and placed as close to the forks as possible. The ballasts and relays will be hidden with the other electronics in the tail.
I will change out the gaskets in the engine once I pull the engine when I make the subframe/repaint.
Old Streetfighter Motorcycle Forum Post 04-02-2010, 12:21 AM   #10
isoto34
Milehigh Project
Noobie
isoto34's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
isoto34 is a NOOB
Keep up the good work. I also have a xj600 project that I am working on.
isoto34 is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived isoto34!
Tags
1994 yamaha xj600, copper, seca, seca ii, xj600
Thank you for viewing Casper's 1994 Yamaha XJ600 in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Casper's 1994 Yamaha XJ600 on Custom Fighters Streetfighter Motorcycle Forum
