How to Wrap your Tank in Carbon fiber (and do small parts) - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Paint and Bodywork
Paint and Bodywork Anything to do with fabricating bodywork, composites, prep and paint work goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > How to Wrap your Tank in Carbon fiber (and do small parts)
Old Streetfighter Motorcycle Forum Post 09-23-2010, 11:23 AM   #1
Knifemaker87
builder in training
Knifemaker87's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 03:45 AM
Knifemaker87 is a wicked helpful, well liked member!Knifemaker87 is a wicked helpful, well liked member!Knifemaker87 is a wicked helpful, well liked member!Knifemaker87 is a wicked helpful, well liked member!Knifemaker87 is a wicked helpful, well liked member!Knifemaker87 is a wicked helpful, well liked member!Knifemaker87 is a wicked helpful, well liked member!Knifemaker87 is a wicked helpful, well liked member!Knifemaker87 is a wicked helpful, well liked member!Knifemaker87 is a wicked helpful, well liked member!Knifemaker87 is a wicked helpful, well liked member!
Fighter of the Year Winter Buildoff Winner Fighter of the Month
Default How to Wrap your Tank in Carbon fiber (and do small parts)
Okay... so i wanted to try this an thought it came out pretty good so far and wanted to share. I have done composite work before, but not on a tank. (i will be adding more pictures tonight)
I am working with a damaged CBR600 tank. the beauty of this is that the Carbon fiber will not only blend minor imperfections, it will also protect the bondo. Plus, because there is metal underneath you dont have to worry about making sure it is gas-proof and crash proof.
I got the tank dents all worked out and the sprayed it with primer. Some wet-sanding to get it smooth and then a gentle cleaning with soap and water. as with painting, in order to get a good end product you have to do your prep well.
So... #1 clean the surface you are going to bond to.
then.. #2 you cut your overlay material to size. this keeps you from wasting valuable time and material while your resin is mixed.
in this case i am using carbon
then, #3 you make sure that alllll your stuff is in order. that means brushes, gloves, solvent,
or anything else you spread that resin. (no pic.. sorry)
#4 Coat the entire surface FIRST. this allow you to get better adhesion as well as giving the cloth something to "stick" to. (keeps the pattern pretty too)
my hands were messy, so no pic of this stage. imagine a primer colored tank covered in resin
#5 lay the cloth down and smooth it evenly (symmetrically too if possibly) so that it stick to the surface. the resin i was using had a pot life of 12 minutes so i got my sister to help lay the resin. (this is why preparation is key)
#6 brush the rest of the resin on the smoothed cloth and continue to monitor how well it is adhering to the curves of the part. certain areas will want to pull away or bubble... just just brush it back down. the resin in the fabric will take longer to set up that in the mixing cup (due to the volume)
so here you go...
you are done.... sorta
you will want to trim the excess off before it cures too long. You can cut it off with scissors with a low layer count and semi-hardened resin (prolly your best bet) then... put another layer of resin on. and it looks like this:
Now, you do not want to leave the tank like this.. (or maybe you do) but it will need block sanding just like other body work, and prolly another layer of resin, but that is really all there is to wrapping a tank. not so hard.
Now... if you want to make something not stick, you would do what i did for the under-tail panel
#1 prep/clean... just make sure it is smooth and clean.. ( i have also added material extending past the edges to make sure i get all of the part that i want, no ragged edges.)
#2 Wax. i use car wax first, then after buffing that out, i use some bowling ally wax. works great. technically at this pint you could put resin on it and it would most likely not stick, but use some PVA (poly vinyl Alcohol) and that will make sure it doesn't stick.
#3 Cut you material.. this time you have to cut your layers. depending on how thick/heavy/flexible you want it.. cut out your layers. I used i thin layer of carbon one very heavy layer, three heavy fiberglass (for thickness and expense) and one more thin carbon fiber.
#4 Get ready.. materials layers "mold"
#5 Now, you want to mix the resin and again, apply the resin first to the "mold" then lay your first layer of glass or carbon. this is the most important as it is the one that you will see (usually.. ) then, smooth the cloth down spreading the resin through it evenly. repeat for each layer.
i didnt leave those globs of resin on there.. i promise.
again, i apologize for lack of pictures. messy hands. i have more stuff to do, more pictures to come.
#6 let it cure before attempting to remove it. i really wanted to try and take the part off as soon as it looked cure. DONT DO IT! until the resin has fully cure (overnight is usually good) even if you manage to remove the part successfully without destroying it, your part can warp or deform after removal.
save yourself some heartache go drink a beer find someone better looking than yourself to hit on, and come back later... (much later if you are lucky *wink*)
anyway, till next time yall!
thanks for reading.
~Chris
CBR 600 F2
http://www.customfighters.com/forums...ad.php?t=33094
"Instigator" Virago Build-off thread:
http://www.customfighters.com/forums...ad.php?t=75337
"Inistigator" discussion
Knifemaker87 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-23-2010, 11:36 AM   #2
DecepticonDon
Elbow Grease is Cheap
DecepticonDon's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 04:45 AM
Flip Offs: 301
Flipped Off 143 Times in 38 Posts
DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!
Default Re: How to Wrap your Tank in Carbon fiber (and do small parts)
nice write-up man! rep!
Originally Posted by robsroadeater View Post
dont want no skanky slagbag hangin offa yer short arm mate
Project: Daytona 675
Operation: Kwak Attack
1991 Tidecraft B.O.A.T. build
DecepticonDon is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-23-2010, 11:37 AM   #3
endo
The Soft Serve Enigma
endo's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 02:45 AM
Flip Offs: 73
Flipped Off 96 Times in 82 Posts
endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!
Supporter of the Streetfighter Build for Charity 2007 Streetfighter Buildoff - Most Complete Theme
Sweet, can't wait to see a finished project
Project Redefyned 7/11
If I have to explain, you won't understand.
RIP Michele "MadMadame" Monroe, 30Apr80-24Mar12
RIP Gavin "Greencheezeeta" Butts, 5Oct83-8Sep09
endo is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-23-2010, 11:39 AM   #4
CK 187
CAPTAIN AWESOMEŽ
CK 187's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 631
Flipped Off 470 Times in 171 Posts
CK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too much
Default Medal Supporter of the Streetfighter Build for Charity Supporter of the Streetfighter Build for Charity
damn. that tank came out good man.
CK 187 is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived CK 187!
Old Streetfighter Motorcycle Forum Post 09-23-2010, 11:52 AM   #5
WoodK61000
Clutch it up already!
Senior Fighterer
WoodK61000's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flipped Off 27 Times in 7 Posts
WoodK61000 is making some friendsWoodK61000 is making some friendsWoodK61000 is making some friendsWoodK61000 is making some friendsWoodK61000 is making some friends
I like that. A lot actually.
I dub thee: "Herschel Walker Cuyler Them Dawgs Is Hell Don't They"
"I have reinvalutated the saturation and I have convaluted that you ain't wild! Ya mild" Early Cuyler
Look me up on facebook. Blair Hughes
http://www.atlantaimportcollisioncenter.com
Bike-less at the moment. First time ive been without a bike, dirtbike, or quad since I was 4 years old. Sadness.
WoodK61000 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-23-2010, 12:02 PM   #6
bwh998
Flip Offs: 10
Flipped Off 50 Times in 43 Posts
bwh998 is a name known to allbwh998 is a name known to allbwh998 is a name known to allbwh998 is a name known to allbwh998 is a name known to allbwh998 is a name known to allbwh998 is a name known to allbwh998 is a name known to allbwh998 is a name known to allbwh998 is a name known to allbwh998 is a name known to all
damn that tank looks nice.
bwh998 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-23-2010, 12:24 PM   #7
Knifemaker87
builder in training
thanks guys! like i said.. it isnt very hard...you should try it!
i am going to sand it down this evening and possibly put another layer of resin on it. i'll post pictures then, and i will also update the post with more pictures of "in process"
thanks for the Rep and the comments..
lata
~Chris
CBR 600 F2
Old Streetfighter Motorcycle Forum Post 09-23-2010, 12:30 PM   #8
daniels
Senior Fighterer
daniels's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flipped Off 6 Times in 2 Posts
daniels is a good noobiedaniels is a good noobie
So is this just putting CF on top of the parts and leaving it or replacing the parts with a cf part? I guess I just don't get covering something in cf. I've never been much into the whole cf thing just for looks. I can see using it for weight reduction though.
daniels is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-23-2010, 12:48 PM   #9
Knifemaker87
builder in training
this is just wrapping one side in carbon fiber. it is still metal underneath. and while i really do love how it looks, it also does serve a purpose. there was a pretty bad dent on one side of the tank and while i was able to get most of it pulled out i still had to recustruck the proper curves with bondo. The carbon fiber ensures that the bondo is safe, and keeps the entire surface of the tank protected.
there is no weight reduction, however, it only add about 1 lb. (and since i am replacing the stock battery with a Li-ion.. i am okay with it.
CBR 600 F2
Old Streetfighter Motorcycle Forum Post 09-23-2010, 12:54 PM   #10
bwh998
Flip Offs: 10
i really hate painting so this is an awesome option for me. where do you get your carbon and resin from?
This user High Fived bwh998!
Thank you for viewing How to Wrap your Tank in Carbon fiber (and do small parts) in the Paint and Bodywork section of our streetfighter motorcycle forum. I hope you found it useful!
Paint and Bodywork - How to Wrap your Tank in Carbon fiber  (and do small parts) on Custom Fighters Streetfighter Motorcycle Forum
