Ammadien's 86 7/11 - Anna Molly - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Ammadien's 86 7/11 - Anna Molly
Old Streetfighter Motorcycle Forum Post 11-01-2011, 09:04 PM   #1
Ammadien
ZUK ATTaCK
Ammadien's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 06:33 PM
Flip Offs: 35
Flipped Off 4 Times in 3 Posts
Ammadien is an amazingly helpful member with a good attitude!Ammadien is an amazingly helpful member with a good attitude!Ammadien is an amazingly helpful member with a good attitude!Ammadien is an amazingly helpful member with a good attitude!Ammadien is an amazingly helpful member with a good attitude!Ammadien is an amazingly helpful member with a good attitude!Ammadien is an amazingly helpful member with a good attitude!Ammadien is an amazingly helpful member with a good attitude!Ammadien is an amazingly helpful member with a good attitude!Ammadien is an amazingly helpful member with a good attitude!Ammadien is an amazingly helpful member with a good attitude!
Fighter of the Month 2008 Streetfighter Buildoff - 2nd Place Supporter of the Streetfighter Build for Charity
Default Ammadien's 86 7/11 - Anna Molly
Here we go fellas -
Inspirational quote I found that I dug to get it rolling...
"This man beside us also has a hard fight with an unfavouring world, with strong temptations, with doubts and fears, with wounds of the past which have skinned over, but which smart when they are touched. It is a fact, however surprising. And when this occurs to us we are moved to deal kindly with him, to bid him be of good cheer, to let him understand that we are also fighting a battle; we are bound not to irritate him, nor press hardly upon him nor help his lower self." - John Watson
Plans -
Alum Tank/tail/shroud/fender
r1 rear and front suspension - 5 spoke wheels
1127 kat motor - velocity stacks(if I can tune em) with gsxr cam(s) and custom muffler
billet triples/risers
Old ass headlight with HID set up
Braced frame
Alum subby
Dirty bars
Aftermarket oil cooler with AN - fittings
Prolly other stuff as I go
Pics:
How she sits today -
The frame has been drilled to accept the r1 swing arm pivot bolt. And I chopped off the old subframe/suspension mounts prior to today.
Motor -
r1 pivot bolt, rethreaded and cut off with new SS nut machined out of 303 stainless.
Random bits -
So there it is, wish me luck figuring out how to bang this alum out.
Nate
2010 690SMC pics - SUMO!
2012 Build thread 86 7/11 yammy suspension - Anna Molly
2013 Build GL1000 8lbs 40 stone, Discuss
2015 Winter build KDX - E-Fighter
2015 Winter Build - Discuss
Ammadien is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 11-02-2011, 06:45 PM   #2
Ammadien
ZUK ATTaCK
Flip Offs: 35
Default Re: Ammadien's 86 7/11 - Anna Molly
Threw the motor in. Seriously easiest motor swap ever.
Swingarm on too to check how much work there would be to get the sprockets and wheel to line up. Pretty close on first try. Might need a small spacer for the front.
Looks nice and meaty in the slabby frame -
Nate
Old Streetfighter Motorcycle Forum Post 11-03-2011, 09:39 PM   #3
Ammadien
ZUK ATTaCK
Flip Offs: 35
Gonna need an offset front sprocket - anybody have a source for them for 1127's? Lemme know in the discussion or pm!
Well upon some research, looks like the output shaft splines are all the same for the old oiler's to the newer stuff? So I should be able to pick up a 1/4" offset sprocket for a 1000 or busa and it would work?
Nate
These people High Fived Ammadien!
Old Streetfighter Motorcycle Forum Post 11-09-2011, 08:02 PM   #4
Ammadien
ZUK ATTaCK
Flip Offs: 35
Boring update but with pictures -
Making a bowl in a stump for metal work -
Wood slapper w/o leather yet -
First try after some annealing, some hammering, some planishing, a little wood slapper-ing and some sanding. Just a test piece to see if we can get the polish nice without an e-wheel. And some patterns for frame bracing/boxing.
Oh and thanks to Piester for figuring out the sprocket situation, should be pretty easy.
Nate
Old Streetfighter Motorcycle Forum Post 11-17-2011, 05:27 PM   #5
Ammadien
ZUK ATTaCK
Flip Offs: 35
Got to work on the subframe mounts -
cut some alum out of the chunk.
Faced and layed out
More metal working tools -
Piester sent me a 520 offset front sprocket for shipping costs - what a fella!
set of headers from escort1991 -
So still some designing to do on the subframe mounts. Waiting on my triples to get finished to settle the rear wheel/swingarm in the frame and then I need to make mounts for the rear suspension. Then make a spacer for the swinger. Then it'll be a roller and can work on aesthetic stuff. I want to use square tubing(i think it'd go better with the boxy tubing used on the frame/swinger) for the subframe but it might prove to be more trouble than it's worth. Waiting on a paycheck to buy more alum to use for boxing the frame in. Thanks for looking!
Nate
Old Streetfighter Motorcycle Forum Post 11-26-2011, 12:47 PM   #6
Ammadien
ZUK ATTaCK
Flip Offs: 35
6 hrs later and I've got one mount finished?! Or close to finished. Here are some pics -
I'll prolly break the corner a little to flow better. Going to make a boss to weld the subframe too that will have the bolt head buried in it. Turned out pretty well for my first machining attempt.
Here is the test piece after more and softer planishing for the tank/body work alum.
Looks much better now and I may be able to get the finish I want.
Thanks for looking!
Nate
Old Streetfighter Motorcycle Forum Post 12-08-2011, 04:52 PM   #7
Ammadien
ZUK ATTaCK
Flip Offs: 35
"Finished" the subframe mounts. Prolly gonna knock off that top corner.
Rough cut out pieces for boxing the frame in.
Swinger set at 12 degrees when the frame is level.
Waiting on the triples to be finished to get the wheels/swinger in the frame finally. Tons to do but waiting on some money to come in to buy supplies. Made a stand for the engines too...not pictured.
Nate
Old Streetfighter Motorcycle Forum Post 12-15-2011, 02:25 AM   #8
Ammadien
ZUK ATTaCK
Flip Offs: 35
Kinda ghey update. Birthday dinner tonight, family bought me a new lens for the camera.
Nifty 50mm for the cannons. Super pumped about it. One of those things you always wanted but never had the spare cash to buy.
Pic of the new box with the old lens -
1/35 shutter sitting on a chair.
New lens, sitting in my hands at 1/500, shit light of the cheesecake my bro made for my b-day lol, serious -
Gotta buy some filters before I use it in the shop.
Nate
Old Streetfighter Motorcycle Forum Post 12-15-2011, 08:02 PM   #9
Ammadien
ZUK ATTaCK
Flip Offs: 35
Mocked up the front end just to see it. Finishing up the spacers for the swinger and sanding the frame boxing pieces to fit.
Nate
Old Streetfighter Motorcycle Forum Post 01-02-2012, 03:15 PM   #10
Ammadien
ZUK ATTaCK
Flip Offs: 35
Started work on the clutch cover bits -
and got some metal in for the subframe/bracing -
I also ordered the left over stuff to get the swinger/rear wheel set for sure. Triples are supposed to be done soon too.
Nate
Tags
7/11, slabby
Thank you for viewing Ammadien's 86 7/11 - Anna Molly in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Ammadien's 86 7/11 - Anna Molly on Custom Fighters Streetfighter Motorcycle Forum
