Erki's RF600r - Ugly Duckling - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > Past Streetfighter Buildoffs > 2013 Streetfighter Buildoff > 2013 Buildoff Entry Threads
2013 Buildoff Entry Threads All 2013 Buildoff Entry Threads Must Be Posted In Here
CustomFighters.com Streetfighter Motorcycle Forum > Erki's RF600r - Ugly Duckling
Old Streetfighter Motorcycle Forum Post 11-01-2012, 09:57 PM   #1
Erki
Pinstriper4fun
CF Lover
Erki's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 06:16 AM
Flip Offs: 4
Flipped Off 9 Times in 3 Posts
Erki is a splendid one to beholdErki is a splendid one to beholdErki is a splendid one to beholdErki is a splendid one to beholdErki is a splendid one to beholdErki is a splendid one to beholdErki is a splendid one to beholdErki is a splendid one to beholdErki is a splendid one to beholdErki is a splendid one to beholdErki is a splendid one to behold
Winter Buildoff Winner
Default Erki's RF600r - Ugly Duckling
I'll get in on the action this time of year.
Was all together a few days ago, Work done up till now.
Ditched plastics, CBR tail fit, subframe modified, 636 rear wheel roughly fit, rattle can paint job.
Bike $2100
CBR Tail and light $80
Subframe replacement metal $10
Spraybomb paint job $40
Pinstriping $0
Kawi rear wheel and front end $200
Running Total $2430
But here is how it sits as of right now.
Ugly Duckling build thread
http://customfighters.com/forums/showthread.php?t=61430
Ugly Duckling Discussion thread
http://customfighters.com/forums/sho...34#post1185834
Originally Posted by ultimate fighter View Post
The rf is like the ugly chick with a good personality, but in any situation you can't see your self elbow deep in her without throwing up.
Erki is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 11-05-2012, 10:09 PM   #2
Erki
Pinstriper4fun
CF Lover
Flip Offs: 4
Default Re: Erki's RF600r - Ugly Duckling
Was a balmy 9 degrees Celsius this afternoon. Figured I better take advantage and do a little cutting and welding outside tonight.
Cut the mounts for the passenger pegs off the old lower bar and welded them to the new one.
Then after the sun went down. I mocked up a location for the battery.
These people High Fived Erki!
Old Streetfighter Motorcycle Forum Post 11-08-2012, 10:11 PM   #3
Erki
Pinstriper4fun
CF Lover
Flip Offs: 4
Ok nothing too exciting. Was going to just do some more welding of mounting tabs for the battery tray tonight but since It was snowing I didn't feel like getting the welder out. So just made some templates for cutting out metal when I can. A template for the undertail with the bends I'll need to make on a brake. And also a template for the side just under the tank and front of the seat. Needed something to cover that area.
And a GIMP idea of what the color it may be like. A darkish red with satin finish clear.
Old Streetfighter Motorcycle Forum Post 11-10-2012, 06:43 PM   #4
Erki
Pinstriper4fun
CF Lover
Flip Offs: 4
Went to the shop today and played. Made the rear wheel spacers and started the press fit bushing for the stem swap on the 636 triple. Finish could have been better but they will work fine I think.
Old Streetfighter Motorcycle Forum Post 11-11-2012, 05:44 PM   #5
Erki
Pinstriper4fun
CF Lover
Flip Offs: 4
Who needs a nice heated garage when you have a view like this beautiful snow. Besides winter is only 6-7 months. Need to get work done.
Battery box mounts in.
Bolt welded in to relocate the coil for a spot to put the thermostat.
Old Streetfighter Motorcycle Forum Post 11-17-2012, 02:57 PM   #6
Erki
Pinstriper4fun
CF Lover
Flip Offs: 4
Finished up my bushing for the stem swap. Just need to get to the press to put it all back together. Its in the other bay at the shop and was all locked up today.
Old Streetfighter Motorcycle Forum Post 11-17-2012, 07:50 PM   #7
Erki
Pinstriper4fun
CF Lover
Flip Offs: 4
Ok, I wasn't patient enough to wait until next week to press my stem in. I went and got out my princess auto pipe bender and found a way to use it to press the stem back in. Worked great.
On the piece I made I moved the lip in deeper to allow the stem to press farther in. That way it would put the place for the lower bearing right at the top of the triple since this triple is a lot thicker than the original.
Oh such a great feeling.
Old Streetfighter Motorcycle Forum Post 11-22-2012, 08:57 PM   #8
Erki
Pinstriper4fun
CF Lover
Flip Offs: 4
Not much done tonight. But every little bit helps. Stayed after work and made up the top spacer for the triple. Then wasn't too ambitious but I did a little bending of some metal for the side covers. And had a few helpers.
Old Streetfighter Motorcycle Forum Post 11-24-2012, 08:58 PM   #9
Erki
Pinstriper4fun
CF Lover
Flip Offs: 4
Played with a fuax patina look today just for fun. Think I'll stick to my plan to go dark red though. Also got my side covers mounted. And toyed with an idea of a belly pan with some cutting up of the stock fairings.
The fender in the picture is not the correct one. I need to get a fender for an 05-06 636.
Old Streetfighter Motorcycle Forum Post 11-26-2012, 10:36 PM   #10
Erki
Pinstriper4fun
CF Lover
Flip Offs: 4
Bolted on some metal for an undertail to keep the elements out.
Wonder how much grief I'll get from the law putting my plate back in there?
Id say its clearly visible from the back though.
Thank you for viewing Erki's RF600r - Ugly Duckling in the 2013 Buildoff Entry Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2013 Buildoff Entry Threads - Erki's RF600r - Ugly Duckling on Custom Fighters Streetfighter Motorcycle Forum
