1 - 8 of 8 Posts
OK guys what swingarm will be a direct swap for an 02 yama fz1? Ive been told one from a 99 R1 would work.. input and suggentions!!
I couldn't find any measurements for the width of the pivot. If you think the shock may line up correctly, then I would contact an eBay seller (or two) and have them measure what they are selling.
I would be also interested what might fit. As far as I know not many options, but none is direct.
Dimensions of original FZ1 02' swingarm:
Width in frame 255mm
Width at wheel axle 300mm
Lengh axle-to-axle approx. 600mm
Thanks for reply..I have R6 swingarm waiting in garage together with the known R6 shock upgrade, but I feel this doesn not work.
There is a guy in UK, something like "Fazer guru" nicked Devilsyam. Can be found on many Fazer forums, he had done everything possible to FZ1. If I remember right, He denied this R6 swinger route-I think the upper part meets the undreseat frame/pas.foot pegs and does not allow the shock work fully.
At the end he fitted SSA from CB1000r with a lot of work!
He mentioned that another close fit (not bolt on) is a Aprilia Futura, but I have not had this part in my hands yet?!
1 - 8 of 8 Posts
