1 - 4 of 4 Posts
hello am desperate for help .im rebuilding my 1200 bandit k3 and ive lost me bit of paper with all the diagrams of were all pipe work goes , from the carbs to tank all way to the air system the mk2 have , even were pipe goes from top of motor , am really stuck can anyone please help
many thanks in advance
Isn't as dumb as he seems
G
Easy enough :)
as you are in the UK you can bin the clean air crap & it will run better :party-smiley: so take the whole bunch of crap & throw it over the nearest hedge, make yourself 4 ally plates with gaskets to block off the holes on the front of the engine block, make sure they seal properly, then run a pipe directly from the engine breather to the airbox, this is now the same as a MK1 Bandit, there are no issues with emissions or MOT when doing this
On your carbs the thicker pipe in the centre is the fuel line to the tap the thinner one from the top of the carb is your vac pipe also to the tap & the 2 at the sides are overflows which just drape over the airbox & hang down a little
1 - 4 of 4 Posts
