1 - 9 of 9 Posts
1948 Olds Coupe I used you bracket race. Don't let the look of the car fool you. It's not heavy. With an aluminum headed BBC it was 2725 lbs w/o driver.
It's not a show car. The paint is faded epoxy primer. Solid body. Handmade floor panels. No stock floor left. But its got a rock solid chassis built with TOP SHELF parts. Car eased out 6.50's in the 1/8th mile on a pumpgas 496. Straight and steady everytime.
Set up with motor plates for BBC. TH400 is still in the car. All plumbing,wiring, gauges and ignition box is still in the car. Full exhaust system included for BBC. 10 pt. cage- 1 5/8'' DOM.
All it needs is a big block Chevy and a radiator. Everything else is there!
$4,750 OBO. Clear title in hand. Front suspension alone retails for $3k. Over $10k in parts here. PM me if interested. Thanks
Front suspension is all tubular K-member grafted out of a Fox body Mustang
-QA1 adjustable struts
-Aerospace Components aluminum hubs
-Aerospace Components 4 piston floating calipers (low rolling resistance)
-Aerospace Components drilled rotors
-Fox body manual rack
-Tubular control arms
-Aluminum tie rod sleeves- Heim jointed
-Fabricated steering column/shaft with severe duty u-joints
-Braided brake lines
-Wilwood master cylinder
Rear suspension is ladder bar with coilovers
-Chassis Eng ladder bars
-Rear frame rails are Chassis Eng/ w/5 position front mounts
-Double adjustable Strange rear coilovers
-'91 Lincoln Towncar disc brakes-all stock
-S&W Racecar diagonal link
-All chromoly Heim joints out back
Driveline is TH400- 9'' Ford
----Trans:
-TCI reverse manual valve body
-TCI severe duty sprag
-Hurst Quarter stick shifter
-B&M Super Cooler-stack type with AN ends
-Kevlar clutches and coated steels
-Strange driveshaft-chromoly-1350 joints
-Lakewood rearend driveshaft yoke-billet steel
-Spicer trans yoke
-CSR full coverage scatter sheild- Kevlar <-fooker only weighs 3 lbs!
----Rearend
-Moser axles-33 spline
-Moser spool-lightened steel
-Richmond 4.56 gears-new
-Ford nodular center
-Moser 5/8'' screw-in studs
-Multi bolt pattern axle flanges (Ford,Chevy,Mopar)
Tires and wheels
-Weld draglites
-3.5'' x 15 front
-14'' x 14rear
-Mickey Thompson Sportsman fronts- 26 x 7.5
-Hoosier 33 x 16.5
-Full setup of autometer mechanical gauges still installed-no tach.
-All wiring is still intact- all fused and relayed
-Kirkey aluminum seat
-Sweet Mfg. steering wheel (feather light!) on Wilwood removeable hub
-Dual fuel systems intact- motor and nitrous- Holley Blue and Holley Black- 1/2'' aluminum lines.
-14 gallon fuel cell
-All lexan windows minus windsheild-have original glass on hand
-Has hi/lo headlites, tail lights and brake lights- no back up lites or turn signals needed for this year- will pass inspection!
-Motor plate with travel limiters and midplate included
-Over-the-frame fender well headers (2 1/8") with full side pipes and Bullet mufflers (4'') included
-Deadenbear brake linelock
-Mallory Hyfire Vl ignition box
I'll take the smartass remark as a no. I DID say partial trade.
Sorry dude. Misunderstanding on my part.
Like J said, it is sold , so I thought you were just goofing off. And the way you worded your post I took it as my coupe + cash for your bike.
My bad buddy. No smart ass or disrespect intended. Just goofing off.
1 - 9 of 9 Posts
