1 - 12 of 12 Posts
I have a 1974 cb360 project going on and im in the planning stages right now. Im doing an engine swap (or install since theres no engine in it) and i was wondering what engine should i do? I have someone who is very good at fabricating parts so mounts arent a problem. Im wanting something that will make highway speeds seem like a walk in the park...any ideas? id like to say away from inline four's...to wide for the style im going after.
lb/hp is what it's about!
I stuffed a gs750 into a cl360 frame but you said no i4's. I was also looking into a gs500 engine swap. Never actually did it but it was looking promising.
UnicycleMode
XR400/500/650 all work in that frame and fit pretty nice. SR/XT/TT500 engines fit too, pleny oh power there. I would stay far away from twins or fours honestly if you want this thing to have a respectable power to weight ratio. A big single does the job fine. ;)
(This very uninformative and rather lacking post brought to you by a rather drunk CB360 guru)
I'm looking at doing the same thing to my 78 cb400t and it looks like a xr400/500/650 are the best way to go but aren't cheap
Well i could take a look at inline fours. I'm more performance than looks and i don't think the i4's look bad after seeing a few. A top speed over 150 would be nice haha with good low and midrange as well of course.
No build thread. I just put it in the build thread for the other 360. Basically I got the engine in the frame and then got rid of it and parted out the other 360 too. First pic is the metal that gets removed, there is a little tab on the back of the engine that holds a vent line that needs to be cut off, then wiggle it just right with the help of a friend to keep the frame in one place and I got it in. I'm tall and the 360 is a little bike and here it has a big engine so my knees were really close to the valve cover. That's with me sitting over the stock rear shock mounts.
This is just some conduit I bent up for a mockup of some bracing that was going to be added.
Yes and no. The cb got the disk brake, the cj never got the electric start, and the cl got the scrambler pipes.
1 - 12 of 12 Posts
