With the airbox modded, carbs cobbled together
and a makeshift harness that would impress Tesla in place
Here is a video of it running for the first time in 8 years.
The RFY shocks were an affordable way to get the ride height I wanted in the rear, around an inch taller than the stock shocks. I've owned a couple sets of these. As long as you get the correct spring rate for the application, flush and fill with quality fluid in the correct amount, and have them charged with the correct psi nitrogen, they can be a pretty decent improvement over most standard 5 position preload ujm shocks.
In my case as with many UJM rear shocks, the RFY shock shafts are considerably larger. The body of the shock is mounted to the frame as opposed to the swingarm, reducing unsprung weight, which improves suspension characteristics such as compression and rebound speed as well as overall reactivity. Infinitely adjustable screw type preload is also a plus.
In that pic I was messing with fenders and still had the stock exhaust and whatnot, but I think it shows well enough the direction of the project. I don't have a picture of the stock stance without being strapped down, but here is almost exactly what it looked like before.
