Recently traded for a 1982 Yamaha 920J Virago. This bike has plates from 2005. Cleaned and kitted the carburetors and changed fluids on bike. Rebuilt front wheel cylinder. New battery installed. It seems starved for fuel but a shot of starting fluid in the main intake fired that sleeper right up.........only did the bench sync and 1.5 turns out on idle mixture screws (new with o rings). Then it was helmet and glove time. WHAT a monster to hang on to, I kept the bike in first gear just to check all this out at a lower speed. Lots of popping and some backfires but the torque was crazy (both cylinders firing). I worked the carbs on and off the bike 4 times so far, just finding Steves DIY youtubes helped. Mixture control valve was already blocked off (and yes it tests bad). The rubber boots that mount the carbs to the heads are about $15.00 shipped WITH new O-Rings, it turned out the O ring to the front cylinder was aftermarket and was not thick enough to seal and lots of air was getting in the flow path. You can buy the correct O ring and WAIT for it to arrive. I made a gasket in 5 mins and hi temp RTV'd it to the front cylinder carb port (doesn't slide about, helped in remount)...installed the allen head bolts instead of the OEM's torture types. Installed all stainless steel bolts in carbs also where handy. Was getting dark then, so today I will check for air n vacc leaks. At least it runs now. Have a single carb manny coming soon. I think I better get me a scooter to practice on till I get my brain and body in shape for this real cruiser.
