prepped it for paint. i figured i didnt need primer since the truck liner is thick
looks pretty good but if you look close you can see alot of scratches and uneven spots under the paint. everything else i use with truck liner i will prime
actually found the sticker with the bike info underneath all that paint
everything checks out. sweet
started preping the frame
i think i might put a few more layers on the swing arm to try and hide those scratches more
picked up an intake cam off ebay for $33 total. wasnt expecting it to be perfect and its not. wasnt impressed with it. its not bad but there is some wear and a spot where there is a little chunk guaged out. another is on its way
ended up using a real rough sanding bit on an air sander. took all the paint off including the factory paint and primer. itll be real smooth for my primer now
got my undertail in the mail. scratched it up with some 180 grit for priming. my plan is to do a tail swap with an 02-03 R1 tail
got the undertail and the working, clean tail light (03 R1) for a total of $34 including shipping. amazing deal on ebay
this is the old tail that came with it if anyone is interested. its in rough shape but there arent any serious cracks or damage as far as i can tell. just needs work
old speedometer that came with it. my plan is to buy a new one but idk if i wanna fork out the cash. i want a digital speedometer with a tachometer and a fuel/air ratio guage
Thats where I am as of now. Most of my recent work has been prepping for paint. My plan is to get the frame painted and the intake cam set as soon as i can. i wanna start the wiring before i put the engine in and i need the frame painted before i start that. my color scheme is going to be matte black (some truck liner/rubber undercoat), with dark metallic charcoal silver tank wheels and tail and tannish gold forks as well as tannish gold trim in the engine and rim tape. most of my engine will be matte black. i think im gonna paint the headers matte black and wrap em with black wrap. also gonna put an R6 shock, yzf 600 tank, pod filters, shorter gp style tail pipe, rear seat with peg mounts, new guages of some sort, ducati style head light, R6 front blue dot calipers, new front rotors, some sort of modded rear hugger, fan override, new revolver end grips, new lithium battery, mostly new wiring, risers and mx style handlebars, new gold o ring chain, new rear sprocket....thats all i can think of for now lol not even sure if i can fit this in my budget but any advice so far would be appreciated im learnin as i go.
