1 - 1 of 1 Posts
Read Only
http://minneapolis.craigslist.org/hnp/mcy/4457031678.html
Here is a 97 ducati monster - in MN that might help some people out.
WHEEL FRONT $200.00
REAR WHEEL $175.00
CUSH DRIVE AND SPROCKET $50.00
Brembo 40mm Left Front Caliper w/ pads $85.00
Brembo Left Front Rotor $75
Swingarm/Rear $75.00
Showa NON-Adjustable Forks $195.00
Upper Triple Clamps $79
Frame $200.00
Brembo Rear Brake Caliper / Pads $60.00
Brembo Rear Brake Master Cylinder $35.00
Brembo Front Brake Master Cylinder $60.00
Brembo Clutch Master Cylinder $60.00
Throttle Housing tube cable and handgrip $45.00
Rearsets Footpegs Assembly (Left) $70
HANDLEBAR POLISHED $70.00
Front Axle w/ Nut $30.00
TACH CABLE $30.00
SPEEDO DRIVE $30.00
REAR AXLE WITH SPACERS $40.00
SPEEDO CABLE $30
Bodywork
dash trim panels CARBON $65
Front Fender $75.00
SEAT $75
Gas Tank $155.00 dented but no rust
HEADLIGH $125
HEADLIGHT BRACKET $50
SIDE SEAT PANELS $35 PAIR needs paint
REAR FENDER $55
TIMING BELT COVERS $45
Engine Components
TRANS $99.00
FUEL PETCOCK $20.00
CRANK AND RODS $149.00
HEAD HORIZONTAL $125.00
HEAD VERTICAL $200.00
JUGS AND PISTONS $175.00
STATOR $60.00
STATOR COVER $100.00
CLUTCH CASE COVER $79.00
STARTER $75.00
ENGINE CASES $149
STARTER SPRAGUE AND FLYWHEEL $129.00
INTAKE MANIFOLDS $40.00
Oil Cooler w/ lines $130.00
Clutch Assembly - complete $185.00
Electrical Components
Ducati PICK UP COILS $100 EACH
Left Hand Controls (lights, horn) $50.00
Right Hand Controls (start/kill) $35.00
Fuel Pump Assembly $45.00
Gauge Cluster Complete $250.00
Starter Solenoid $30.00
Voltage regulator - 2-phase $65.00
Rear Taillight $40.00
TIMING PICK UPS $150.00
COIL HARNESS $35.00
Everything Else
TANK LATCH BUCKLE $40
Seat Hinge Assembly complete $15.00
Complete Lockset with 1 original keys $75 NO SEAT LOCK
1 - 1 of 1 Posts
