Thanks!
The last piece for the seat part was the licence plate light. As you can see I use 4 wires to control the tail lights: mutual ground , left turn light, right turn light, run-stop-licence plate lights. Run-stop light is the same LEDs array connected through resistor. This resistor is mounted in the wiring harness on the motorcycle side before the tail lights 4 wires interface.
The licence plate light uses same power source wire as the run-stop LEDs array. Ideally you need 5th dedicated wire to control the licence plate light, but I found there is not enough space in the seat in that area do put one more pogo pin for 5th wire. I did not want to compromise the tail look and mechanical integrity just to have space for one more wire.
So I decided to use 4 wires and connect the licence plate light through LED driver to keep the licence plate light brightness constant regardless if the brake is pressed or not. Originally I was planning to use this LED I found on Amazon
https://www.amazon.com/gp/product/B07K89C3F1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 And the licence plate pocket shape in tail was shaped for this unit.
To keep the brightness constant I bought Supertex CL2N3-G LED driver
http://ww1.microchip.com/downloads/en/DeviceDoc/20005448A.pdf But after some tests I found it does not work for some reason, it changed brightness same as the run-brake light.
So I asked my coworker who is EE guy about what is going on here and how to make it works. After he scratched his head he said that this driver definitely does not work but he can design custom PCB for me with LEDs array and controller all on one board so it will be constant brightness flicker free light for licence plate. He said it is super simple and will take a couple hours and he drawn this schematic for me
Well, it actually took a few nights to design the final schematic and PCB
I gave him the PCB dimensions I need to fit the pocket in the tail and he designed the PCB. Then he ordered the custom PCB boards. He planned to use some boards for some of his own projects so he ordered extra
Then he showed me how to build the board. I applied soldering paste on the board with custom stencil he designed and ordered for this purpose too. Then attached the components on the board under the microscope.
Then we cooked the board on the heat plate to reflow the components. After this I soldered the wires to the board and cleaned it with alcohol and plastic brush
