I relocated the horn behind the oil radiator.
The horn is attached to the CNC machined bracket
And the horn with the bracket are mounted on the highway foot peg bracket
And the horn assembly is covered with 3D printed ABS plastic shroud
I decided to make the whole motorcycle in black color. Originally my motorcycle had blue transparent airbox cover. My options were to buy OEM glossy black airbox cover or to buy aftermarket carbon fiber airbox cover. I decided to buy aftermarket carbon fiber airbox cover. I found one on MDI Carbon website with air ducts https://mdicarbonfiber.com/products...ver-carbon-fiber?_pos=34&_sid=63fc6ec12&_ss=r
I choose Twill carbon fiber fabric style and matte finish. External surface finish of this aftermarket airbox cover is 10 out of 10, but fitment is 2 out of 10. It was not properly trimmed, the mounting holes were slightly off, it also was not symmetrical! Well, after a lot of post processing, trimming and sanding the airbox edges and the holes I make it fits OK.
I enlarged and shifted the front mounting holes to be centered properly
I also had to shift the rear mounting holes
I used Sharpie permanent marker to mark the edges for trimming and erased it with alcohol. As soon as I touched the airbox with alcohol I found alcohol erased also the matte finish on the airbox exposing the original glossy finish. So basically they do glossy finish airboxes and just spray it with matte clearcoat. So did I. After I finished trimming and fitting the airbox I stripped whole airbox matte finish with acetone a covered it with fresh matte clearcoat spray
For the enlarged front mounting holes I 3D printed inserts out of PETG plastic and pressed aluminum spacer inside the inserts
The rear mounting screws required additional spacers to maintain proper fit in the rear area of the airbox. So the aftermarket Buell XB airbox cover MDI carbon sells does not fit out of the box, you need to do some work to make it fits.
For the air inlets I designed and 3D printed snap-in grills out of PETG plastic. This aftermarket MDI Carbon airbox cover is so bad that even the inlet holes are not symmetrical! So I designed left and right grills individually.
