1 - 20 of 428 Posts
Update: Stuff I've done to the bike:
Triumph OE Black Anodized Rear Brake Reservoir
Triumph OE Black Anodized Shift Lever
Triumph OE Black Anodized Oil Cap
Triumph OE Gold Anodized Yoke Nut (removed; re-installed black)
Biltwell Chocolate Diamond Pleated Grips
JPM Coachworks Custom Pecan Leather-Wrapped Seat
Origin Fabrication Side Dumped Exhaust (custom)
^ This was done with the cat in tact, then later done to remove the cat
Black cerakoted exhaust
Powdercoated Calipers (Gloss Spanish Gold, 3x)
Powdercoated Wheels (Gloss Spanish Gold)
Powdercoated Lower Yoke (Gloss Black)
Powdercoated Upper Yoke (Gloss Black)
Powdercoated OE Handlebars (Gloss Black)
Powdercoated OE Bar Risers (Gloss Black)
Powdercoated Side Stand (Gloss Black)
Powdercoated Side Stand Bracket (Gloss Black)
Powdercoated Pegs (Gloss Black)
Powdercoated Shift and Brake Levers (Gloss Black)
Powdercoated Gas Tank Lid + Bezel (Gloss Black)
Powdercoated Rear Subframe (Gloss Black)
Powdercoated Motodemic Gauge Cluster Mount (Gloss Black)
Powdercoated DCC Classic British Style 7" Bucket (Gloss Black)
Powdercoated Swingarm pivot trim (Gloss Black)
Powdercoated lower dogbone (Gloss Black)
Modified Rear Brake Lever (chopped off exhaust mount)
Toyota Spruce Mica Metallic-painted tank (extra House Of Kolor gold flake)
Toyota Spruce Mica Metallic-painted gauge cluster trim (extra House Of Kolor gold flake)
Toyota Spruce Mica Metallic-painted lower tank trim (extra House Of Kolor gold flake)
Relocated horn
Fairing Delete
Chopped/Bobbed Seat frame
Front fender delete
Charcoal canister delete
Continental TKC80 120/70-17 and 180/55-17 tires
Motodemic Single Round Bucket Mount
Morimoto Bi-LED headlamp
^ quick change
Custom Gatling Gun headlight DRL array
^ quick change
Competition Werkes Smoke/Stealth Integrated tail light (removed; replaced with below)
Optronics LED tail light
^ smoothed, lightly tinted, clearcoated
Custom aluminum tail delete section
^ cerakoted black
Pazzo gold anodized long levers
^ re-anodized black
R&G radiator guard (de-badged)
R&G kickstand pad (cerakoted black)
Driven Racing halo gas cap (all black)
Any removed bolts were re-installed for an OEM-like finish and no bare holes
More work this winter:
Custom tracker faceplate with Morimoto Type U LED projector fog lights
Daytona Ohlins TTX Rear Shock
2016 Speed Triple tank emblems
Custom aluminum coolant overflow tank (powdercoated black)
Help from:
Origin Fabrication + Precision Welding
Classic Livery of Atlanta
Mountain Motorsports of Kennesaw
Kickass Powdercoating
Dime City Customs
JPM Coachworks
Motodemic
The Retrofit Source
Carolina Custom Anodizing
Bought my bike about a month ago and it's already being torn apart for a build-up / overhaul. It had 26 miles on it when I started tearing it down.
My inspiration is the Ramarro Street Triple:
Parts already removed to go to paint (the front fender is already at the painter to test spray):
One fatal error I did make was that the bolts holding the headlight mount on to the frame sheared off, so in an attempt to drill them out as they are hardened bolts, the drill bit wanted to go in-between the bolt and the frame:
I will further drill out these holes (to about 12mm) and helicoil all four of those bolt holes back to the stock bolt diameter for consistency.
Realized I personally don't own a crescent wrench, needed to hold the nuts on the bottom of the bolts or they'll just spin freely. Off to buy some new tools!
Also ordered a pair of Biltwell Chocolate grips. The seat will be recovered to match:
OEM header and painted heat shield installed
FWIW the crossover tubes on the header make it a massive PITA to wrap, but I still wrapped those too, hence it looks a little clustered around that area.
In an effort to keep the tail section as clean as possible, the rear plate mount / arm thing can be removed and there's only a small spot about 13cm x 13cm that is left exposed under the tail. I'll make a small piece of ABS for that and my tail tidy is finished.
The plate will be mounted down on the swingarm and still trying to decide about the indicator location.
Here's how it sits as of this writing. Many aluminum parts are at the powdercoater being done gloss black and I need to drain and pull the tank to go to the painter.
The headlights are the main focal point seeing that my life revolves around headlights as-is. This is my life right now: http://www.theretrofitsource.com/, so I need to ensure it has a badass setup.
We're looking into custom making machined and anodized aluminum cylinders that will contain OEM Koito LED projectors from a Nissan Rogue. They're the same projectors as the 2014+ Corolla and 2015+ Camry LED projectors just with round lenses.
Right on! I picked up your single moto headlight on Black Friday last year. I guess you are the one to thank for that deal. Too bad it is still sitting in the box waiting for me to finish my bike :D
Feckin Eejit!
A buddy of mine used a bunch of retrofit source stuff for his e46 \o/
and ugh... you guys have my headlight on closeout when I'm broke :(
http://www.theretrofitsource.com/closeouts/cycle-7-led-headlight-kit.html
Oh well, I'm planning on building my own with projectors :p
Dig the striple dude :D It's my bikes younger, lighter, more agile, better looking... little brother :p
Hack in a barn
THAT, is freaking awesome lol...
Legit goon
Following with great interest
Stupid motherfucker
I remember a very pleasant few weeks when I was shagging a bird who lived up a long gravel road. Travelling that on my Street Trip with road semislicks was great fun! I reckon do it, unless you're only doing it for the look. In which case, go with standard rubber.
It would be just for the look, honestly. In that case, stock tires it is. :rock:
I've also been trying to track down some new wheels, but running into a few issues giving people money:
Galespeed - No reply from main vendor
Kineo - No reply from main vendor
Marchesini - No confirmation of fitment, no reply either way
Noobie
try ask carrozzeria
1 - 20 of 428 Posts
