list of parts/costs
GSX1100 EFE frame £200
GSX1100 Tank £650
Seats + recover £400
Side panels £250
Brembo front brake M/c £237.50
Brembo clutch M/c £184.60
Brembo rear brake M/c £756.40
Braketech front discs £1050.00
Brembo GP4-RR calipers £2350
Brembo 4pot P4 rear caliper £839.70
Domino quick action throttle kit £140
Ohlins forks £2500
Ohlins bespoke rear shock £1300
Bandit 12 motor £500
Yoshimura 40 TMR-MJN's £1600
Red6 billet yokes, cases, h/lamp £2200
Redsix billet battery box £160
LiIon battery £140
Motogadget M-unit, M-lock, M-button, M-blaze
M-view + wiring kit, Pro dash £1600
Motone switch units £80
BST Carbon wheels with Ti fixtures £3200
Martek swing arm £1300
Titanium fasteners £1000+ so far
Carbon front fender £160
Rizoma brake fluid pots + mounts £170
Ti dry break connectors £400
19 row alloy oil cooler £164
6 row head cooler £174
electric cooling fan £60
heat switch for fan £44
oil cooler fittings £275
wassner 1246cc h/comp pistons + carillo rods £2000
WSR billet big block (plus mach) £1350
40mm carb inlet rubbers £160
Pillion grab bar £40
Rear light unit £60
light infill plate £30
seat lock £6
brembo brake pads £200
Titanium pad pins £50
Gilles rear sets £460
OEM Suzuki grommets & bushes £100
Titanium front wheel spindle £200
Titanium rear wheel Spindle £200
clutch plates £143
Sigma slipper clutch £662
clutch springs £15
No plate bracket £15
PC racing billet oil filter £85
side stand £20
Ignitech programmable ignition module £150
Ignitech stick coils £140
Braketech rear floating disc £250
Renthal ultra low bars £60
Yoshimura top yoke stem nut £34
APE s/steel oversize valves, valve guides, cam sprockets, cam chain, valve oil seals,
Yoshi stage2 cams, cam springs & spring retainers £2600
fit valves and port head £850
Yoshi billet brake clevis joint £29.90
GSXR Cam cover breather £30
Racefit legend Titanium exhaust system £1200
Racefit twin fuel filler £850
Racefit Ti paddock stand £200
Pingel fuel tap £144
Carb inlet protectors £120
Second CBR yoke £50
Gasket set & seals for engine rebuild £175
Welding (so far) £200
steel tube (frame brace) £20
Alloy plate ( top shock mount) £30
Tyres £145
Chain and sprockets £200
Brake hoses £150
Pillion pegs & hangers £100
Vapour blast & paint engine £450
Lightened and balanced crank £150
new crank shells £100
SNT billet clutch basket £
GSXR1000 slipper clutch £270
Wego III fuel unit £500
Billet rear caliper hanger £143
Rear shock bracket £55
Rear spring £80
Titanium swing arm spindle nut and bolt £180
Harris Billet paddock stand lifters £66
Pipper cross filters £20
Yoshi paddock stand bobbins £60
Billet electrics tray £134
chain jocky wheel £90
Starter motor £60
Generator £60
Tank straps £150
rear mud guard £80
Clutch master cylinder £30
wheel q/r cups £125
Titanium engine mounts £500
Beer to pay Taff £150+
Still to come
Paint £????
Powder coating £????
Dyno time £????
running total = £41,130 +
