I need to pull my finger out and get on with doing some work, was a bit bad with flu over most of my Christmas break, so didnt feel like
doing anything at all, least of all going down my nice cold shed to work on the bike!!
6mm Alloy plate has arrived for the making of engine/shock mounts, swing arm is needing bits cutting off/welding up
engine crank cases/sump have been sent for Brian to do his magic on.
message from SPS says my Yoshi Cam goodness is in transit from Japan,
Should be picking frame up from **** on Wed, after all the welding is finished. will be getting steering stem pressed into lower yoke whist at Red6.
so i will have things to do as and when i can be bothered to shift my arse into forward gear, and press the "GO" button.
Onwards
