did you print your own enclosure or did it come with the kit?
does using the larger nozzle require different software or does the slicer take care of it?
Printed my own but wasn't impressed with the hotend got to many stopages so taken it off. Think I'm going to make my own.
So back on the stock hotend, with a 0.6mm nozzle on.
You can use any size nozzle you just adjust it in cura (or slicers ) and it takes care of it, It does cut down on some time. The three Yoda's picture, the two smaller one were printed on a 0.4mm the larger on on a 0.6mm the size is different as I changed it to run the tests. You do loose a bit of detail and layer lines are a bit more visable but for prototypes it's fine.
White print is a 0.6mm helmet I'm printing, knocked about 10hrs off the print time and there isn't much detail so should be fine.
Sent from my SM-G973F using Tapatalk
