I'm using SolidWorksNice model. Are you using Solid works ? Or inventor ? or...?
Tig is probably the way to go for the aluminum tank, but I dont have a tig welder. This aluminum solder looked interesting and worth a shot. I'll see how well the nylon tank holds up long term.Very neat solution to hiding the header tank, tig welder would probably be a better solution for an ally tank, assuming that there's any reason to swap the printed tank? Most bikes and cars use plastic header tanks now anyway...
I remember the stock rad on the 750's was fairly big and the 800 originally two rads... how are you keeping the engine temp under control?When I was considering the 2014 vfr800 radiator setup, I found I could mount the oil cooler in the stock location with the stock bracket stacked on top of the 2014 radiator bracket.
All the fins are visible from the front for fresh air, not blocked by the radiator:
When I switched to using the vfr750 radiator I had to come up with something else. The space behind the front exhaust tubes was free and had some good mounting points. I thought since it was close to the hot exhaust it might be a good idea to use a larger oil cooler. Ebay had an RC51 oil cooler available, so I bought that. It has a few extra cross tubes and fins.
I didn't do a good job photographing the bracketry build but here is the finished product. It uses a stainless rod held in place with shaft collars, and a bent metal bracket which is also held in place with collars.
To connect the cooler to the engine I cut up the stock fittings and soldered on some AN fittings. Then connected them with stainless braided hose.
Here are the rear oil fittings:
Then the front oil fittings:
I cut the stock oil line tubing at an angle to align it with the incoming oil hose.
View attachment 154504 View attachment 154505
At the moment I am keeping the engine temps in control by crossing my fingers and hoping for the best. But I think my riding style and location here in the northwest USA should let me get away with it. I have got the temp up to 220 in stop and go traffic, but the fans come on and keep it from getting higher.I remember the stock rad on the 750's was fairly big and the 800 originally two rads... how are you keeping the engine temp under control?
My 750 used to kick out a shit load of heat if I got stuck in traffic on a got day...
