1 - 8 of 8 Posts
Hi all, need a little help here. I want to get a slightly fatter tire under my bike and possible extend it back a couple inches. I heard about some supersport cbs having longer swing arms but have no idea if they will fit my c frame? Anyone know what options are? A direct volt in would great if possible. Thanks
The Hell You Say!!
A supersport swing arm should slot right in. I would also look into a F2 or F3 swingarm. You would either have to weld some shock mounts on it or convert to mono shock but it will upgrade you from a 120 back tire to a 160
The Hell You Say!!
I also have stretched and widened supersport swingarm and a 5.5 rim that will run a 180. If you are interested I could get pictures. You will have to make your own spacers for it though, I don't know what happened to the ones it came with.
The Hell You Say!!
You will have to take out about 4-5mm from each side of the pivot. I would go with something else like I did to avoid modding the frame. Unless you are just dead set on using the F4 swingarm there are better options out there.
1 - 8 of 8 Posts
