1 - 20 of 20 Posts
Bitches love Fighters
well. i ended up with a free gs550 the other day. and its in about as good of shape as that price dictates. from what the po told me it has been sitting for over 20 years. have got it running pretty nicely but will still need some tweeking. hoping to teach the lady how to ride with it too
plans thus far are
delete absolutely everything i dont need to make it move and stop.
wire chop and hide.
gs750e front end
16 inch front wheel
clipons
possibly monoshocked.
it has a 16 inch rear wheel with drum brakes and id like to retain that but monoshocking may require me to swap swingarms and it would be easier to just use the 17 that came with that swingarm. that would give me disk brakes in the rear too. we shall see though
4-1 header and shorty can.
the smallest and lowest seat i can fit in with a cafe or squared off tail only big enough to fit the smallest battery i can get my hands on.
maybe rearsets
coil relay mod
that is probably it for now
onto some pictures
tire rot all the way around
all but 6 wires of this will be deleted
sweet air filters bro
pile of "optional" parts the factory included
tempting
should be a lot higher at the coils. did the coil relay mod and it now sees 14 or so when its running. spark is so much brighter now. i can post videos showing the difference if anyone would like
yum
thanks. and im sad to say thats the 7/10 covered up in the back
sweet, another gs aircooled build. Kai is about to get his greedy hands on a 550 frame.
I have the swing arm/disc brake setup and wheels from my 78 gs 1000 if you want to switch to disc..
i am on the lookout for an a/o so we will see what happens.
started working on the seat.
cutting foam down
didnt like how it was coming out so decided to start fresh
wasnt going to let me low enough so start from scratch
seat template
trying to decide between clips and dirty bars. opinions?
welded up the frame
decided to use this to make my seat. its hard rock maple
little time with the file and
means of attatchment
through the tank and frame with a spacer and a nut on the botton
welded up some bars for it. still need to make a rear mount for the seat. cut up the electrical. actually pad and cover the seat. figure out a front brake master. still need tires but may have that covered. suggestions?
Man that looks good. Simple and clean. Cruise craigslist for some take off race tires, cheap.
havnt done much to it lately. chopped the top triple up. shaped it. smoothed it. baked on some paint. clipons. new front tire.... again. cleaned up the wiring but i think i will be chopping the wiring down to only what it needed to get it running and then make an add on harness for the lights. love the stance and how it feels to sit on it.
top trip midway through
shit picture of the top trip after paint
front end now
stance
still need to make a battery box. finish the carbs/intake/exhaust. and seat.
Grabbed that kerker 4-1 header off my old gs750 that went through the flood. Primary's are spaced too far apart and the part that slides into the head is too big of a diameter so I chopped the flanges off that header and chopped the ones off the stock header.
Welded sleeves onto all the stock flanges
Bent the primaries on the new header and slid them on. Very tight fit. Tacked them and then welded them up.
Ugly welds but they are strong.
After some grinding and hammer and dolly time to shape the mid pipe I welded it like this
Super tucked.
And some Bmx pegs on the swing arm pivot bolt. Super comfy.
raised the front end back up and mounted the clipons below the top triple
thinking i may raise the rear end or the back of the tank a bit and add a few inches of padding to the seat before i cover it. not sure yet
G
I like everything about that apart from the seat height have you thought about chopping the seat rails a couple of inches ?
Any lower and it would be uncomfortable to ride honestly. But I'll figure out more as I go
Tore into the carbs as I got a dynojet kit. They are much dirtier than I remember them being. And me with nothing to clean them with
1 - 20 of 20 Posts
