21 - 40 of 42 Posts
time is running out......
Discussion Starter #21
I hear ya. I think a thick USD upper is gonna get in to the radiator in a hurry. Unless you can find a set of yokes with some serious offset to them. Your stock yokes already seem to have a lot of offset.
:CK187: Might have to gooseneck that beast :D ??? GOOSENECK????
Hardtail it and go attack chopper with it. :rock:
pic no worky
re-tarded
works for me, but here it is rehosted on imgur
Goosenecking is chopping the head tube off and shoving it forward. I know that's more than you want to do, but it'd be about your only option to de-rake this thing with your space constraints up front.
Love me a nice chop :) Nothing fancy here, but a good view of a gooseneck.
Discussion Starter #26
yea I figured it meant messing with the rake. those forks are super short.
well. I'm going to put it back how it was and just ride it. might pik up a Goldwing today. I need big motor :Evil_smile:
Discussion Starter #28
well I messed with the fuel. unhooked all hoses. single hose to carb to up in the air and sprayed carb cleaner. with choke on it wanted to fire over.
before I ripped off all hoses. I pulled the one off the fuel pump...and fired...no fuel...so pump is bad?
that's fine. il delete and use a regular tank.
I need to find a regular type of tank or at least something that drips into carbs.
need to make it run before more work on it. or its pointless
Discussion Starter #32
got a new stem. put forks back on. will gooseneck possibly now.
wanting a drop seat.
very much bobbing back end off.
need to stretch this shaft drive somehow ??? enough to sit between rear wheel and motor.
ditching resever tank and fuel pump. modifying tank to drip into carb and vent at the top.
will be a ratty bar hopper style.
getting rewired in 2 weeks and pressure washed and tank done
Discussion Starter #36
chop chop chop
welded up a fender bracket. made fender from KZ650 front fender
anyone know what other bikes had hydraulic clutch? id like a more compact lever
science math
what if .............
OR
BOOGERS. dismantled 78 kz650 forks and found they work great
GOTTA FIgure out the other side since its a stud and not a coupling bracket.
could drill a big hole in the fork piece but its too thick for the stud.
Discussion Starter #38
well good morning everyone.
welcome back to episode 14 of the most boring uninteresting bike build.
no idea what I'm doing.
wasted like 4 hours milling the inside of this socket(no place to buy bar stock around here)
and there she stayed. not much done on the bike.
about to just give up. need more arc rods or fix mig.
Discussion Starter #39
decided to redo it. and do it right.
ratty is one thing. but stupid and half-assed is another.
waiting on a seat in the mail.
fixing tank.
redo wiring.
maybe new handle bars.
universal hydro clutch and brake levers coming. the oem ones are stupid and huge
Discussion Starter #40
worked on the tank for 3 miliseconds. had gotten more metal in my eye:stupid:
chopped off reserve tank nozzles. will weld shut and put in a gravity fed nozzle.
WHOEVER DID THIS IS AN IDIOT. WHO WOULD DO SUCH A THING......
21 - 40 of 42 Posts
