1 - 20 of 28 Posts
Super Moderator
I have come to the realization that I didn't ride my Gsxr as much as I thought I would so it's up for sale to fund some personal goals and my build-off project. Most details and lots of pic in my build thread but if you don't feel like looking through it see below...
Specs:
'89 Gsxr750
'92 USD forks with Racetech 0.95kg/mm springs
'01 Gsxr600/750 front fender
Zrx1100 fairing, headlight and bracket with custom tabs
'02 Gsxr600 cluster (everything works except it says "CHEC" because of no FI, electronic speedo pickup with SpeedoHealer)
Superbike bars with TAG risers
Newer Gsxr switch gear (full functioning)
Completely untouched main wiring harness
Relocated ignition switch
Newer sealed battery
Powdercoated Lockhart Phillips front turn signals
Stage 1 Dynojet kit with K&N drop-in filter
Supertrapp full SS exhaust (rare)
Tracsport HD engine covers
Very close to being fully safety wired
'94 Gsxr750 swingarm
'92 Gsxr600 rim (5.5")
Bridgestone BT-016's (2 track days and a couple small commutes (~200miles))
New front brake pads (2 track days and a couple small commutes (~200miles))
New X-ring chain (2 track days and a couple small commutes (~200miles))
Aluminum undertail with FZR600 taillight and turnsignal integrator
Bike had 9,408miles when I got it and like stated earlier I've added about 200miles. The speedo reads 30k+ due to the gauge swap.
The bad (nothing major):
The tail section needs bodywork (not a problem if your chopping the sub off).
Big dent in tank (have a nice, clean one to got with bike)
It has a jump when starting from a stop (no problem up/down shifting once under way).
Rear rim is half painted/half stripped
Carbs may need a cleaning as the idle hangs slightly.
Oil cooler bent but no leaks.
Rear rotor warped
Clean (not salvage or rebuilt) Ohio title in my name. Located in Akron, Ohio.
Looking for $2300 obo as it sits right now.
PM, e-mail (magrimsATyahoo.com) or text 330-32nine-952five.
Later, Doug
watches you sleep.
Hey man quick question, what year is the switch gear off of and was it a direct plug in or did you have to splice in the plugs from the old controls? The switch gear on my 92 might be shot and if it's not too involved this would be my first choice. Thanks in advance and good luck with the sale.
Super Moderator
I made a write up in the "Electrical and Lights" forum on how I did it. It can be found here.
Later, Doug
Super Moderator
Now I'm thinking about keeping it and doing more trackdays with it. I would eventually get something newer with plastics and clip-ons if I sold it but I kinda like standing out on the track...I really need to make up my mind.
Later, Doug
Super Moderator
Semi-necro-bump!
Swapping tanks to the good one, swapped out the warped rear rotor to a straight one, switched to '05 Gsxr1000 rear shock to help stiffen up the rear and give a little more ride height.
And relocated to St. Louis area in Missouri.
AND.....price dropped to $1800obo.
I need to sell to finish my GPz build.
Later, Doug
Super Moderator
Man I hate to say it again but this forum has been soooo broke for a while. Its really a shame. Lots of awesome bikes and parts have been up here fo a long time. I hope you sell this soon.
I know. I haven't posted it on CL yet as I much rather see this go to a fellow CF'er. I've even given thought to parting it out but definitely rather not.
Later, Doug
Reactions: ROBBO
Super Moderator
Bump it up.
Still need funding for the Gpz and someone needs an awesome base for a Spring project.
Later, Doug
Super Moderator
TTT. A splash of paint and maybe an oil change and this will be ready to ride come spring.
Later, Doug
1 - 20 of 28 Posts
