1 - 5 of 5 Posts
lb/hp is what it's about!
Thanks a bunch! Is that black part just a flange? Does it look like I could trim that back without cutting into the housing in order to make those dimensions a little smaller? If could you measure the minimum size the light could be?
Noobie
it's a rubber with a collar inside, sorry my previous measurement was a little bit off
here i re-measure it:
without cutting, metal bracket and tail lamp socket, it's 22 x 14.5 x 8.5
if you cut the place where the bracket bolted, it's 17.5 x 13 x 8.5
sorry for my bad english​
1 - 5 of 5 Posts
