1 - 13 of 13 Posts
I need to know the size of the steering stem nut. Ive asked teh dealer and looked at fiche's and noone can tell me. Its either a 34 or 36mm I believe. The reason I ask is because I need one and I found a custom one I want instead of spending the same amount on a stock one. Thanks!
the mad doctor
i believe it SHOULD be the same size as the stock one off any katana/gsxr/pretty much any suzuki made before 96. they almost all use the same stem and bearings.
The katana uses a different setup. It actually uses a bolt with an attached nut or whatever on it. Like I said, the guy says in the auction there are two sizes, I just wanna make sure i get the right one the first time lol
the mad doctor
gotcha. i have an 86 and a 99 gsxr at the shop, best i could do as far as measurements go.
Im referring to what size socket/wrench fits on the nut.
the mad doctor
ooooooh, ok.
a big one?? lol
i believe it's a 36. i only say that because i don't even think i've ever used my 34mm socket, but the 36 gets used quite often.
LOL, this is the hardest thing to find out,. I wonder if he will send me 1 of each and ill just return the other or sell it to someone on here.......anyone interested in these?
And he has this one for the R1 or R6.....and I guess whatever other yamaha uses this size nut.
your gonna put a wrench or socket on those?? id say go with a rag on it and use an adjustable.
Argggg my hopes keep getting raised when I see a new post hoping someone has the answer lol. I emailed him and asked if he would just send 1 of each and I would return the one that didnt fit.
tell that guy hes an idiot and nuts and bolts arent measured by what size socket or wrench takes em off!
lol well suzuki made two different sized nutes. One uses a 34mm and one uses a 36mm. If I know what mm nut goes on the spindle then Im good.
1 - 13 of 13 Posts
