1 - 16 of 16 Posts
I am thinking of picking this bike up to build a streetfighter out of it and wanted to see if anyone here would know if I would have to get longer cables and wiring or if there is enough slack for a set of dirt bike bars with risers?
Thanx Jason
i had to get longer front brake lines. and re-route my cables to reach. . . not that i have a gsxr, but i did do a dirtbar conversion. heh.
Blaze said:
Ok, Thats sound cool. Now, were do you go for longer brake lines?
you have to go to a big & tall motorcycle shop! :LolLolLolLol:
http://www.spieglerusa.com/
your probably gonna want like two 12" and one 18" ( i should measure)
:muah:
Fuuuuunnnnnnyyyyyy! Thanx for the site!
You say I will need a 12"and a 18" but I thought I would just need one brake line? Why two? There is the on from the master cylinder to the joint were it splits...am I missing something else?
no. i guess not. just changing the one upper line would be fine. . .
when i changed mine. i went from stock to stainless lines so i had to buy three pieces and all the connectors.
I recomend that you lose the conector where the lines split and run 2 lines, 1 each directly to the caliper you lose a few more grams weight and it's easer to find any problems later in the future, you'll just need a longer banjo bolt for the master cylinder :D
....and two long cables. :D
good point gixerman!
1 - 16 of 16 Posts
