1 - 5 of 5 Posts
G Force Junkie
Hey all,
Fitting a '92-95 GSXR 750 Swing Arm to my '89 GSXR 750.
Arm and linkage that I bought has some crappy homemade lowering links that I don't want to use.
Does anyone know the code # stamped on the dog bone for the '92-'95 arm?
All I'm finding on Fleabay is the 33E off 96-99, and 35F links off 00-05
Factory # looks to be 62640-17E10-000.
The shock linkage for my application is the longer one that resembles a J, not the shorter triangular that the '96-'05 ones appear to have.
Any help with the code # and or where to find one that isn't the dealer would be great.
Clark
Super Moderator
The 92-93 Gsxr600, 93-95 Gsxr750 and 93-98 Gsxr1100 should use similar linkages (dual dog bones with a tube welded in between).
You'll need to use the knuckle from those bikes or use spacers at the lower dogbone attachment as the knuckles are wider than the O/C 750's knuckle.
Later, Doug
G Force Junkie
Thanks Yan,
Fowlers is where I started the search but the factory fiche doesn't mention any code on the links.
Streetfighterkz says he has a 750W braced arm on his '89 and is going to check for code stamp and measurements.
If it is supposed to have the 33E or 35F links , I'm golden ,as there are plenty on eBay.
1 - 5 of 5 Posts
