1 - 8 of 8 Posts
0.o i didn't do it
Ok so here it goes, 94 swings arm pivot bolt....25.2-6( can't remember exact but that is really close) diameter of.
Stock outer sleeve in swing arm bearing on the k6 swinger measured 22. Sumtin id
Now from what I have gathered through reading the pivot bolt is supposed to be smaller on the 94 and the k6 is supposed to be bigger. I have the complete opposite of what I've read... What the he'll am I doing wrong. Any suggestions as to how I can make this work.
0.o i didn't do it
easiest way is to use a pre k6 arm when it was still a 25mm pivot bolt but thats not very helpful..
I hate you!!
you can do a bearing swap and run your stock swingarm pivot bolt and inner swingarm spacer
That maybe the way to go. Did some research and the outer pivot bearings in both the 94 and k6 are the same size. Thanks for the help
0.o i didn't do it
Agreed it looks sharp. Once I get the rest I'll have a better idea of what needs to be done. Next project to be completed is the ladys cafe so she can ride in stead of being a passenger
1 - 8 of 8 Posts
