1 - 2 of 2 Posts
Abministrator
ALL DISCUSSION ABOUT THIS BUILD SHOULD BE IN:
ab420's Honda CRF 100 Build Discussion
BEFORE:
Bike:
2005 Honda CRF 100
Mods:
Holes drilled in airbox
Spark Arrestor removed from exhaust
Front radiator shrouds removed
Front fender and tailpiece cut and painted
Side plastics painted
All cutting was done inprecisely (and is imperfect...) all painting was done in not nearly enough coats of spray can, and done rather quickly. So really, there's not much done to this bike at all yet...
Before Pictures:
http://www.customfighters.com/forums/attachment.php?attachmentid=810&d=1161543879
http://www.customfighters.com/forums/attachment.php?attachmentid=811&d=1161543888
More to come!
Abministrator
Re: [MINI] ab420's Honda CRF 100 Build
My plans thus far are to:
re-shape the front fender some more, and trim sore more off the back part of it behind the wheel to make it more narrow, sand and paint
re-shape the tailpiece some more, sand and paint
possibly remove, otherwise, do something to... and sand and paint the side plastics...
I would like to get some bigger handlebars, not sure what yet...
I will either be modding the gas tank (have to check the design of it to see if it's possible), or replacing it with a different one, that may or may not be customized depending on what I find...
I want to take apart the seat, reduce and reshape the foam, and re-cover with new material (not sure what yet...)
I want to rejet to accomodate my hacked airbox/exhaust
Paint and color scheme are undetermined as of now...
Now... the "wish list:" the stuff that only gets done if the budget allows:
I would like to get street tires...
I would like to get a big bore kit...
I would like to get a bigger carb...
I would like to improve the suspension...
I would like to improve the braking...
However... I want to keep the costs very low on this build, so basically whatever I find the cheapest is what gets done! :LolLolLolLol:
1 - 2 of 2 Posts
