1 - 10 of 10 Posts
Grinder Happy
I'm taking the ignition out of my sv650, and i know to melt the red thread lock and i know to use a torx security t40 bit.
The T40 does not seem to be a very good fit however. is this normal ?
It isn't a very good fit in what way? Have you tried the next sizes up and down?
sickboy
you are using a safety torx bit right? One with a hole in the center?
Grinder Happy
Yeah t40 security torx. thats the right size, i just wandered if there was another that had squarer ends on the teeth or somthing?
hate us cuz they ainus
There are 2 different torx bits. The other is called torx 2 or something like that. And the difference is in fact the angle of the splines. Ive only ever seen it once though, on a newer road tractor
G
Yeah there are 2 sorts of torx bits as above, ive been caught out by that one myself
If you are removing the ignition & replacing it with something else do you know about the security diode ?
1 - 10 of 10 Posts
