Status
Not open for further replies.
1 - 8 of 8 Posts
CAPTAIN AWESOME®
Enter here for August 2016 FOTM, same rules as always.
minimum of 50 posts
4-8 good pics of your bike (and tell us which one you want used for judging)
list of mods and such
must currently own said bike
past entries allowed providing
1. you did not win
OR
2. you've made measurable upgrades since last time
deadline is the 21st before we start voting
Entry posts only. All others will be taken out back and have their toenails removed
throw me hat in the ring , see how the auld girl gets on now that she's been on the road a while
first off, my voting pic
then some others
token anodized tat (it will be un-goldened soon)
model - 1995 Honda CBR900rr Fireblade
Kawasaki zx6r front wheel
Kawasaki zx10r brake discs and calipers
Hel brake lines
Kawasaki zx16r forks
yokes (triples) by me
fairing mounts by me
handlebar clamp by me
Renthal fat bars
renthal grips
bar ends by me
Buell fairing modified by Sebspeed customs
carbon front muddie
carbon screen by Sebspeed customs, painted by John O'Hara
Ohlins steering damper
mount made by me
stem top nut modified by me
lock stops by me and Callum
900rr tank , de-seamed by me. skinned in carbon fiber by Deeks and I
billet gas cap
1995 frame
1999 engine
standard rad
silicone hoses
hardcore fighters belly pan, skinned in carbon by me
subframe by me
monster seat, modified by me, recovered by a guy in Devon
monster seat cowl, skinned in carbon fiber by deeks and I
tail light surround by me
number plate and tail light mount by me
stainless headers
link pipe by me from existing link pipes
akrapovic Ti can, repaired by me
later model blade arm modded to fit by me
zx10r rear wheel
supersprox rear sprocket
pirelli diablo tyres
sachs aprilia mille rear shock
linkage plates by me
battery tray by me
loom fitted by Scott
race rear sets
might be more , not sure
more....
clutch cover by me
powdercoating by Powderworx
mini indicators - ebay - mounts by me
reg rec - srad
manual cam chain tensioner
OK, since there is only 24hrs or so to get another entry i'll throw in my Duc. I took some pics before I started it's current strip down and engine swap while it was still running in "café" form. Not expecting to win of course, just can't let Yan win by default! Someone else get in on this too please!
Rebuild ongoing right now, but essentially as it stood:
Fork swap to 748s Tin Forks, triples bored and new billet clipons,
Swingarm swap to Alu,
Carbon fenders, carbon heel guards, billet Oberon bits and bobs,
Power Commander II, mounted on the dash for blinky-lights amusement,
Big-bore headers from 620SSie
Stubbie and cored Scorpion cans,
Engine Painted, Stainless Bolts (almost everywhere on the bike),
Home made cut-away belt covers,
Home painted rear seat cowl,
Custom crash bungs (tried and tested - 0% damage to bike @40mph :D)
Vote pic VV
Belt spinning fun:
Because I don't want Cookie to beat me...
2000 Ducati 996 Strada
LSL top clamp and bars
Monster headlight, flyscreen, and associated brackets
Ohlins damper
DP keyless gas cap
Sargent seat
Magnesium wheels
Carbon belly pan, heel guards, heat shield
Cycle Cat highly adjustable foot controls/pegs
FIM UM222 single injector chip
Full Termi exhaust
Full floating front rotors
PSR clutch slave
Pazzo knockoffs levers
Waterpump slider cover
Sweet STM frame plugs
STM 41 tooth aluminum rear sprocket
First one for vote winning purposes:
Bought, not built. :fu:
ok... too many yellow twins.. needs more carbon i4's..
'98 suzuki 600 srad
Srad 750 forks and yokes
750 Tokico 6 pots, k8 radial master
billet brake line converter
K4 carbon fender
Carbon wrapped yz450 number plate
LED spot lights on billet mount
Spiegler braided lines/billet adapter
Pro Taper bars on 2" billet risers
Tailtech speedo/tach
Radiantz LED blinkers
40mm/r6 throttle tube
Carbon wrapped tank
Stainless bar ends
fazzo levers
'99 engine and ecu
K&N filter
K1/k2 1000 titanium headers
One-Off undertail/midpipe
Re-jetted to suit
APE chain tensioner
-1/+1 gearing
VFR swing arm with one off linkages to make it work
One-off aluminum chain guard
GP speedworks carbon 750 tail
Battery/electrical relocation under carbs
One-off seatpan/subframe/platemount etc.
Protek rearsets
k8 rear shock, one-off adapters to make it work
Rear rez. delete
Radiantz LED taillight array
voting pic...
Thred closed and voting will be set up as soon as me or Mike can figer how to do it .
I am a wee bit worried that Noah'eatabullit' and Craig'CK187" aint bin on here forra while ,hope there OK.
Gonna have to wing this one mates ;)
1 - 8 of 8 Posts
Status
