So ive trimmed the front guard but it looks ghetto. Rideable.. but uglier than a hat full of arseholes. Proper zx10 fender on its way. Fitted the new front pads (fucked up the order on the rear so had to reorder)and ordered a master cylinder rebuild kit for the front. I finally got around to checking the bars for level and symmetry..Damn i was way off judging by looking at it. Need glasses
Ive decided to put the reflective tape on back of the chain adjusters(both sides) and see if that passes.
Still have a laundry list of things to tidy up but one good thing with the lockdown is that i have some time.
The main thing i want to tackle is how and where to mount the Koso gauge ...
I dont really want anything forward of the top triple and i have the steering damper in behind. I dont want to go behind that as itll be too night I guess That only leaves on top of the triple..... but how?
Initially i thought id make a bracket off the top triple bolt... Im in two minds about it ...any ideas ?
List of shit to do
- [ ] Replace left hand switch gear
- [ ] Install rear brake banjo light switch
- [ ] Install indicator flasher relay
- [ ] replace handlebar tubes
- [ ] install 3/4 Master cylinder piston
- [ ] Bleed brakes
- [ ] Install Brake pads rear
- [ ] Wire up gauge
- [ ] Replace clutch switch
- [ ] Install rearsets
- [ ] Mount gauge somewhere
- [ ] Paint and fit front guard
- [ ] Install Rear shock
