in the september issue (most recent) of streetfighter mag, the cover bike is a hornet 600 (mostly). the dood who built it, did an exhaust setup under the bikes motor (a la buell). however it starts going towards the rear, but then U-turns toward the front wheel. the slipon is actually facing the front tire....:nuts:
he setup a block off plate over the exhaust exit with a 1 or 2" gap between the pipe. this way the exhaust exits out the sides, and wind doesnt go down the pipe in the wrong direction.
the said result is supposed to be an amazing effect:
"essentially the revs build as you'd expect from such a lump, not bad, reasonably torquey and then around mid revs the engine inexplicably spins up in a total instant and is banging on the rev limiter like a nun in heat at the doors of of the monastary
LolLolLolLol
the bike revs through to the limiter even in top (gear)! in fact the power comes in so hard and fast its a bit scary"
it goes on to say that one of the owners friends has a K2 gixxer thou that he ran with:
"it becomes evident that no matter how hard his friend tried, he couldnt out drag the hornet to the ton, and they did try- every set of lights- and the bloke became increasingly pissed off and started accusing matt of having a blade motor on the sly..."
anyone know whats going on here?? how does this mod make a 600 hornet keep up with a k2 gixxer 1 thou????
:wtf:
:wtf:
