1 - 15 of 15 Posts
So I am sure this has been asked before, but I recently picked up a Bandit 1200 and I am in the process of upgrading the front end. I have three goals.
change out the front forks to a more modern set up with better brakes and handling.
retain the factory gauge cluster & speedometer
use factory suzuki parts if possible so that custom triples aren't needed
I have been looking about, but I don't see any Bandit specific posts about how to go about this using factory parts with out the purchase of high dollar triple trees. Most of the conversions I have seen use the current forks with the Monoblock brake set up, but I don't see mention of how they run a speedometer or if it is possible to retain the factory speedo. Any advise or suggestions with pics and specifics on how to perform the task would be much appreciated.
UnicycleMode
100% of the swaps to modern forks I have seen revolve around swapping the steering stem from the Bandit bottom triple tree to the one associated with the desired fork set. This is either accomplished by it being a stock Suzuki setup (busa, TL, GSXR forks) and the stem either swapping directly, or a thin collar being machined to take up the space of the likely smaller Bandit steering stem.
As to the speedo thing, most people find an aftermarket unit that needs a magnet pickup (the brake rotor bolts work great for a small round magnet mounting point) and runs the speedo wiring from the pickup to the gauge on the bars via the brake line routing to keep things clean and unnoticed when you have an electronic speedometer conversion.
Early 90's GSXR USD's, some, had a cable operated speedometer and a Bandit wheel fits in with a custom spacer on the brake lever side of the bike. The brake calipers bolt right up too. Just needs the stems swapped directly over. ;)
Not sure who's this is, just found on google images, but its got the speedo drive cable, as said, it's a pretty direct swap. GSXR1100 and 750's from the early 90's sported these forks. ;)
Super Moderator
You can probably get better springs, emulator valves, 4-piston calipers with upgraded pads, and a nice M/C for your stock setup and meet most of your criteria for less money than a different setup may cost you.
Just a thought...
Later, Doug
ShamanFighter
Hayabusa swap. . simple stem swap with collar on the top yoke prtion. gen two calips bolt right up to the busa wheel.
Reactions: CK 187
hate us cuz they ainus
I have the 90s 1100 front end with the 6 piston calipers and a busa master I'd be willing to give up. Pm me if your interested
This is an old thread, but I gotta throw in my 2 cents:
First, anyone who quotes "it's just a steering stem swap" is deserving of a fist punch to the Jimmy - Why, because they obviously never did one!
Second, I did...a full front fort swap on my 2004 Suzuki GSF1200S and rear shock swap.
Parts:
Front
2004 Hayabusa Front fork and steering assy (Ebay) $168
2004 Hayabusa Front Wheel/Fender combo (Ebay) $300
2004 Hayabusa OEM rotors (Ebay) $200
2004 Bandit triple tree/steering stem (Ebay) $60
2004 Bandit roller bearing set for steering stem (Amazon) $30
All new bolt hardware + blue locktite (dealer) $65
Front Bandit brake calipers bolt directly to Hayabusa forks.
Rear
2004 Hayabusa Shock (Ebay) $100
All new bolt hardware + blue locktite (dealer) $45
I had the front forks and rear shock overhauled and set to factory default for installation (dealer) $350
The handling is vastly improved with this mod, hell, it looks like it should of came from the factory (pic)
IMG_1626 by Matthew Darbro, on Flickr
Parts:
Front
Rear
This was not an easy project, but not hard either. If anyone reading this and wants to do the same - PM or email me and I'll give you a play by play of what to do.
I will say this because the question comes up a lot - Steering Stem swap: The most important step being the steering stem pressed out of a Bandit and replacing the steering stem on your Hayabusa triple tree.
1. Have the correct parts
2. Have a bearing press
3. Ensure you have a base to hold the triple tree(s) secure. You will not be dealing with a flush/flat lower triple tree. There are casting nubs that will interfere with what your doing. I ending up machining a custom plate from 1/2 in (12.7mm) armored plate (don't ask).
4. I used a metric deep well socket for the business end of the bearing press.
5. When pressing out the steering stems make damn sure you press it out correctly. From the inside out - not the flush side - if you do your screwed.
6. it's real important you support the ALLOY steering triple tree during this procedure. They are not steel and will warp under the high pressure of the press - I know..trust me...ugh.
Fuck it, let's do it live
That's pretty much all that's required to get the new bits to fit on. What new bits you put on, and how much you pay for them, is up to you.
I did a Busa front end swap on my B12 recently and I didn't pay anything for it :D
For my daily driver needs I'm really glad I did it. The little things like upper steering yoke needing a custom bushing (upper bandit stem is about .060 under size to the Hayabusa yoke), the steering lock not lining up, or the brake lines needing re-routing (slightly) were unforeseen challenges. Took me three days overall and really happy with the results. This is my first Bandit and I was surprised at the power, but as my urban assault vehicle for Central Texas the handling needed a nudge.
Learned a lot during the process and just wanted to highly recommend it. Know if only I could step down the rear seat about an inch. I did buy some drop links, but they don't look very heavy duty - recommendations?
Will Tig For Food
I happen to have a k4 gsxr 1000 complete front end down to the last bolt and all the controls...
I just picked up the cleanest first gen B12 I've seen in a hot minute it so happens.
Following the Fork chart, it looked like the difference in length wasn't but a few mm, but the builds I've looked a suggest it's a couple inches.
Which is correct? I'd very much prefer using what I have if possible.
Also, I can't find information on the length of the front swinger at the pivot for brainstorming possible swaps on the back end.
Fwiw, raising the rear shock mount while keeping the geometry is not a problem if my front forks end up being too short. I fab for a living so the metal work is locked down.
Thanks for the help guys, as soon as I start piecing it back together, it's tore down to the frame, I'll start a build thread and actually contribute instead of lurking for 5 more years lol
For my rear shock swap I modded the OEM drop links (increased length .40in). This will give you the travel you need. The original OEM's installed with my Hayabusa shock raised it 1.5in and was a bit to much for my inseam.
Note: aftermarket drop links were for lowering a stock bandit 1-3 inches - does not work when lowering with a different shock o_O
2004 Suzuki Bandit with 1in aftermarket lowering drop links. Does not work with a Hayabusa shock swap. by Matthew Darbro, on Flickr
2004 OEM drop links from Suzuki Bandit 1200S_.40in mod for Hayabusa rear shock swap by Matthew Darbro, on Flickr
Parts:
Front
Rear
What did you do to get the stem to fit in the top triple tree how much did it lower your front end
1 - 15 of 15 Posts
