1 - 11 of 11 Posts
Baron Von Crashoven
Was looking for some help I'm putting USD on my bandit and want to no if a bandit 1200 stem is same size and lenth as the bandit 600 because I think the b6 stem is welded in place but the b12 isint so I can use it in the custom billit yokes that came with the gsxr1100 front end thanks for any help
I would say no they are not the same as looking through my haynes manual, the 12 has a greater free spring length suggesting the forks on the 12 are longer than the 6, it doesn't mention any difference on the bottom yoke that I could see either so not sure that the 1200 stem isn't welded either, buuut, if I'm wrong, I'm sure someone will be along shortly to set me straight!
Piston broke
Thats just the forks. B12 stem is the same mate,I have one here if you want any measurements to make double double sure,but I know blokes who've fitted whole 12 front ends on their 6.
Baron Von Crashoven
Thanks for help the forks are from A 1990 gsxr1100 a think but the yokes are custom made billit ones a thought bout grinding weld of but was worried about fucking up the stem would prefer just to get one I could push out
Piston broke
You can have this one for £20 plus a bit o' post mate. Bit of a nick where someones removed the bottom bearing with a grinder,but all sound and out of the yoke already.
Should fit no problem. I used the 91 1100 tubes w matching yokes. Check my build.
escape from prison planet
Some bandit 6 stems are different, slightly smaller where it presses into the lower triple. Ask me how I know. But MOST are the same as 12s. I have a 12 stem pressed into a Busa lower and mounted on my 6.
Sent from my iPhone using Motorcycle.com Free App
Baron Von Crashoven
That be great reaver if it's not to much hassle I have a PayPal account but never used it for anything apart from eBay so not really sure how to send money u might have to talk me through it
Piston broke
No worries mate,I'll send you a PM. :thumbsup:
If you're doing a USD swap than a 1200 stem is the easiest option. I pressed a 1200 stem into a 93 GSXR 750 lower triple for my 600. The 1200 stem dimensions are identical and use the same bearings.
1 - 11 of 11 Posts
