I cut up a set of stock fairings to make a temporary bellypan. It is kind of Meh, but with some trimming I think it can be made to look pretty decent.
Fire away with you visions, I will be working on it a tad.
After I trim it, I want to create a mold for either a fiberglass or CF version.
Only things of note are:
the front where the inlet triangle mounts is a little above the inlaid black stripe.
I'd like to remove the stripe either with fiberglass or cutting below it
The rear tail will be a 1098 Duc, in the coming weeks. I will also move the headlights a little lower and out since it looks off to me at the moment.
:shocker:
:shocker:
