1 - 7 of 7 Posts
I've got one of those led brake lights where the turn signals are integrated into the light.The turn signals turn on but don't blink.i put in an electronic flasher relay and still the same.Do I need some resistors?if so,what size?Im also not running any front signals.
sickboy
Yup you need a resistor. Most people use a 6ohm 50 watt. Their like $1 at radio shack.
It might have something to do with you not running any front signals. Might still not be enough resistance in the circuit? Also have you started the bike and tried turning on the signals? I know it sounds weird but one of the other members had an issue where the lights wouldn't blink and when he started the bike they were fine. Don't know if this helps but I am in a similar boat as you. Am going to get some resistors myself and see if that works but I have leds on all 4 corners
1 - 7 of 7 Posts
