1 - 18 of 18 Posts
Got this as a daily for a good price looked alot cleaner in pics than it was
The fairing lugs were cracked the bodywork in general tatty and that doesn't matter as it was always going to be chopped about. So I sold the bodywork for 400
Fuel tank Tire Wheel Automotive fuel system Automotive lighting
I love it bit more work needed needs to trim the front another 15mm to get the sides to meet the frame as intended and so mounting holes line up on the seat and subframe and will be filling blending shaping for a smooth look but I think it's the nuts
Discussion Starter · #14 · (Edited)
This is the only rear light I had I have got two led tail/stop lights designed to fit any flat surface be perfect for this seat unit
but fk knows where I put them. so for now this will have to do.
so welded on these two small tabs in order to mount it
t's a temp thing and I will get a better light and fitted at the rear face of the tail piece also considering a twin
stumpy underseat exhaust
Are those Hella headlights? I am surprised you had room to put them in the middle, but it looks like you are relocating the ignition/steering lock parts?
Looks like it will be a blast when you are done
1 - 18 of 18 Posts
