1 - 14 of 14 Posts
The Soft Serve Enigma
There are specific caliper paints available, but as Haelo said, any enamel based high temp paint will work.
Wannabe
LoL, just pointing out that you might as well spend some good dosh now or you'll end up repainting the calipers next time you bleed the brakes or if you have to disconnect the brake lines for some reason. Brake fluid + the wrong paint = bare metal in record time, and I fully suspect that few things would make you feel worse then watching the paint you just applied to the calipers run down your wheel because of a little brake leak.
1 - 14 of 14 Posts
