1 - 13 of 13 Posts
Just bought a Vapor Stealth speedo to fit to my fireblade, and have a couple of issues, i could do with some help on.......
1. Do i run a positive and negative lead to the battery to power the vapor speedo?
2. Where exactly to fit the speed sensor magnet on the disk and where exactly to fit the speed sensor? (any pics would help)
Thanks.
electrics are not my forte , but I'm sure you can run it straight from the battery, if I remember correctly it goes into a hibernation mode after not receiving a signal from the magnet, putting the back light out , easiest way to fit is to araldite the magnet to a disc and mount the pick up on a simple bent piece of steel / aluminium, held by the spindle clamp bolts
Thanks for your replies
Think I am going to dig out my wiring diagram and connect to the wiring harnesses standard speedo power supply.
As for the speedo magnet, was going to drill a 6mm hole in the disc and fit the magnet, anyone have a view on this idea?
Thanks
godamit I mis all that stuff;) over here tis 'JB-weld'
breaking stuff since 1978
there is already a power wire for the gauge cluster from factory so there is no need to run another one fused. Tell me what wires you are planning to run. I know orange and light blue are the turn signals, pink is factory speedometer. Its pretty simple to wire up a gauge.
1 - 13 of 13 Posts
