1 - 2 of 2 Posts
Hey folks.
I would like to stick an 05+ cbr front end on a 1980 Honda CM400E... just curious what a swap would entail. I know jack about machining, steering stems, bearing sizes, etc... if you could lay out a step by step of what I would need to do, I would greatly appreciate it.
Thanks!
Master of Vril
You'll probably have to have a custom steering stem machined and pressed into the CBR lower triple. Then figure out what you want to do with the cable driven speedometer. Looks like the bearings are the same size so you should be ok on that but you'll have to find out for sure. This link should help.
http://www.allballsracing.com/index.php/forkconversion
1 - 2 of 2 Posts
