1 - 6 of 6 Posts
2 stroke sniffer
Hey guys
I need a way around the headlight drama I'm having. With the headlight unplugged the bike doesn't start but as I'm streetfightering it I'll be fitting a different front light. What's the best way around this failsafe?
moron with a hammer
Your post was up for just over twelve hours. The F1 wiring experts are probably all still in bed. Give it a minute.
If it doesn't get any bites here, post it in Electrical with a wiring diagram, and it'll be solved pretty quickly.
If you put a staple on to the poles on the connector from the wiring harness it'll tell the ECU or whatever that's its hooked up and will let the bike start
2 stroke sniffer
Apologies, I'm in the UK so most of the time the guys I need help from are asleep and in the US.
Either way, thanks for the imput. Just gotta find out which wires are which that need bridging.
Taa. :)
moron with a hammer
No worries, and I wasn't trying to be a dick. Usually, with stuff like that, it's just a matter of finding which wires to tie together, but occasionally, it's something totally oddball like "use a 35 ohm 5W resistor to tie this wire to an ignition hot source". I figured you'd be better off with an answer from somebody who actually knew something about the bike than whoever just wandered in.
1 - 6 of 6 Posts
