1 - 5 of 5 Posts
Perpetual Project
I have a a LiFePO4 battery that needs charging, an 8 cell one I think. Anyone had to charge these things? Mind has sat for the last year or so and will barely keep the lights lit now. I think I read on an ebay listing to "charge them like a normal 12v battery" so does that mean hook the thing up to my trickle charger and let it charge?
Help appreciated.
watches you sleep.
NO! Not quite anyways. Yes you can charge it with the right charger. I think it needs to charge at 5 amps or something like that. You DEFINITELY can't charge it at a high amp rate. I gave up on those finicky fucking things. You can get a gel cell the same size for $80 at autozone and they can run a Harley 1200 engine. I know that doesnt help you it's a lead when that lipo shits out.
Perpetual Project
A neighbor of mine has a special charger for his rc planes and car batterys, he seemed to think he could do it, but googling it it seems a finicky process...
Link to the autozone gel cell would be appreciated...
0.o i didn't do it
I have a ballistic battery. Their instructions say you can use a normal charger. Don't exceede max charging amps. They say to watch the battery with a volt meter and when it reads 14.4 volts to stop charging and it should be fully charged..I have an .8 cell bat myself.
Sent from Motorcycle.com App
Your motorcycle doesn't know the difference between a lead and lithium battery, so if "regular" charging was bad for them they wouldn't last in service very long.
Stick a battery tender or other trickle charger on it, you'll be fine.
1 - 5 of 5 Posts
