1 - 13 of 13 Posts
Rat Fighter
Doing a little spring cleaning and i have a few things i don't need
01 gsxr 600
brake calipers (front and rear)
tail light
04 gsxr 600
front fairing stay
04 F4i
swing arm
fuel pump
front fairing stay
04 Fz6
clutch cable brand new still in factory packaging
fighter transplant in NC
you happen to know if any of thos calipers will work on forks from an 02 gix 750?
if they will then I'm def interested in a set
All star !!!
The 01 600's will bolt right up for you.
I think he 04 600's are radial, IIRC.
The Soft Serve Enigma
100% I've done the swap lots. They're identical.
(cheers smiley goes here)
+1 ^^^^
What is a "front fairing mount" is it the part that holds the gauges/headlight??
thats a FAIRING STAY BRACKET.
Naked from the waste down
-Chulada- said:
the 04's are radial the 01 are not. i'll ask a freind of mine at suzuki about the 01 unless DougZ is 100%
Just to pass along a tip...If I was in that situation and you wanted to know quickly, just go to google images and type 04 gsxr:
Then look at the pics.
04 gsxr
Then look at an 01 gsxr
Rat Fighter
yes but that doesn't tell me if they will bolt up to the 02. i know which are radial and which are not i just didn't want to say yes they will fit just bc they look the same only to find out they don't.
how much you want for the 01 calipers? front and rear?
1 - 13 of 13 Posts
