1 - 4 of 4 Posts
Anyways on the first pic I want to un plug and re route under the frame where it will exit near the purple or red arrow .most likely go with the purple. Will the radiator melt it if i go low? Insullate with heat shield?
Second pic is of three plugs that Im 99% sure go to nothing(I should check a diagram to be sure) I kind of want to remove them.
Any other ideas, tips, links to threads or any info would be awwesome.
Also want to clean up some hoses. Going to un plug the green one at the arrow unless you guys think it will mess shit upby shortening it.
Also not too sure what to do with the this hose going from the top of the radiator that goes to the little reservoir. Probably cant do shit but it doesnt hurt to ask.
Elbow Grease is Cheap
Go with the routing away from the radiator.
don't cut off any electrical bits without knowing what they are
That hose(in green), what is it for?
get rid of the stock overflow and find a better looking container. almost anything can be used. there are a couple of threads with pics of possibilities. relocate it closer to the radiator so the hose going to it doesn't have to be soooo long.
1 - 4 of 4 Posts
