201 - 212 of 212 Posts
600er Bandit mit 1052 ccm GSXR Motor
Discussion Starter · #202 ·
I had to machine the thermostat beforehand with the milling machine because?!?!
NO PLACE!!!!!
149992
149993
149994
Discussion Starter · #203 ·
I also continued a little with the bracket for the tachometer / headlight.
That is roughly how it should sit.
149995
149996
149997
Discussion Starter · #205 ·
Before that I had exchanged the lens headlights:
150005
The new ones are LED and a little bit smaller.
150006
Size comparison
150007
I had made the new bracket out of sheet metal a long time ago.
150008
150009
150010
150011
due to the upstream connection, there was again little space available.
Discussion Starter · #206 ·
Somehow I got everything into the small open case / bracket.
150012
150013
You can leave it that way. Fits !!!!
150014
As already mentioned, this version had been made a time ago.
The LEDs are smaller. I don't like the black border around the headlights !!!!!!!!
150015
Discussion Starter · #207 ·
I searched the internet for a couple of angel eyes that might cover the black border. Find what you are looking for !!!!!!!!
BEFORE
150016
LATER
150017
Will be glued in soon !!
150018
150019
The angel eyes have to be set a little deeper. The 3 retaining lugs have to go. But on the whole, it doesn't look bad.
150020
Discussion Starter · #209 ·
I now have 4 !!!! Weeks spent finally getting the engine to run properly. The guys from Ignitech from the Czech Republic helped me very well to set the ignition (Ignitech TCIP 4 full version) correctly.
The motorcycle starts very well and has a smooth engine run. The carburetor is not even adjusted. This should be set once on the engine test bench.
I already had the sleeves for the lambda sensors welded into the manifold for this purpose.
150186
The weld seams from my welder are worth seeing !!!!
150187
I had the lambda connection from the display welded into the intermediate pipe.
150188
150190
I also got the encoder and its holder finished. Otherwise not much has happened because I am messing around with the cockpit.
150189
150191
