21 - 34 of 34 Posts
600er Bandit mit 1052 ccm GSXR Motor
Discussion Starter #21
So first turned the connecting pieces for the O-rings with the lathe.
148476
The whole thing 4 times, of course.
148477
Then the connecting pipe on the rotating part.
148478
The phase is used for a smooth transition.
148479
Then I asked my boss if he had 4 stainless steel arches for me.
148480
And then another small piece of pipe to connect the arches.
148481
So far so good. Now align everything and then weld everything.
148482
Looks like original or what do you think about it ??????
Discussion Starter #24
At some point I caught a used cylinder on Ebay. HOORAY !!! Broken too, so lucky! Could throw up !!!
148496
Discussion Starter #25
Well if you already have 2 defective cylinder banks, you can make a whole out of them. Since I have to remove the liners from the cylinder, I will immediately put the liners and the gearbox with "windows"
148497
148498
148499
148501
Then renew the cross-cut with the honing brush.
148500
The 4 best pistons were then selected and renewed.
Discussion Starter #26
@ yantosh:
Here you can see again that the first 1100 GSXR gearboxes have no room for larger sockets.
148502
Discussion Starter #27
The 4 most beautiful pistons get new piston rings and new oil control rings. New piston paint is also applied. Applied with an airbrush gun. Goes great !!!!!!!
148505
148504
148503
The piston crowns really polished up and the whole thing into the oven. Please ask your wife first. Save a lot of trouble!
148506
148507
148508
I think looks very good. Better than new.
Discussion Starter #28
So continued at the stern. This part is to be built later with a locking mechanism. All of this is then welded and no longer screwed.
148516
148517
148518
148519
148521
The 2 small original angles on the frame are removed and the new profile tube is attached directly. The old profile tube was 50mm x 20mm and the new one is 50mm x 40mm. And the lock for the "MOKO" hump goes into the profile tube.
148522
148523
Discussion Starter #29
A rotating part is used to pull 2 locking bolts.
148524
148525
148526
148527
Two stainless steel arms later pull the bolts.
148528
148529
148530
148531
And this is how it should look from above.
148533
148534
Discussion Starter #31
Thank you @ MDM for the words of praise.
It continues with the locking. I had to provide the POM blocks with a groove because of the profile tube.
148573
148574
Then the locking bolt with spring.
148577
148576
Put everything together
locked open
148578
148579
Finally the end pieces and you're done
148580
148581
this is how it looks finished. the counterpart from the stern then engages there
148582
Discussion Starter #34
The footrest system will later be placed 2 cm higher. You could do that with footrests from the accessories store. Point 1 the footrest systems that look nice are far too expensive. Point 2 the footrest systems that are not that expensive are not nice. A vicious circle. So I take the originals and I will add them to my taste.
148589
148590
It's only a small step, but personally I like the footrest systems best. and black powder-coated a beautiful pair.
148591
21 - 34 of 34 Posts
