So let's go !!!!!
First off with the old paint!
Then open the first side of the frame.
As you can see inside the bracket for the engine and shock absorber can be seen there.
This bracket should stay as it is.
Now roughly cut open the back side !!
The 2 lines (one at the top left and one at the bottom right) indicate the slight kink in the frame. This made it impossible for me to use the milled frame in one piece.
So I divided the milled frames into 4 pieces each.
And now the whole thing is being welded by my professional welder at work.
So motor and swing arm out again and off to weld on the straightening bench.
